Hauppauge MediaMVP 86001 Rev D3A vs. model 1000
Can anyone tell me if there is a (significant) difference between the older MediaMVP 86001 Rev D3A and the newer Model 1000? I already have a rarely used Placeshifter license that I would like to use with an MVP, so I'm looking for a reasonably priced MVP and found an 86001. Will it work just the same?
Thanks in advance for the help.
Dedicated Sage Server, Headless: Intel Dual Core 2.5GHz (OC'd to 3.0 GHz and very stable), 2GB RAM, WinXP Pro, PVR-150, HVR-1600, 2x HVR-2250, Avermedia Duet, 1x HD-300, 2x HD200, 1x MediaMVP, 9TB Network storage and continually adding... |
Anyone Using ATSC HDTV & Hauppauge MediaMVP | John.Kelly | SageTV Media Extender | 7 | 12-18-2006 11:53 AM |
Hauppauge MediaMVP same as Sage Extender? | Ryand833 | SageTV Media Extender | 4 | 10-20-2006 01:53 PM |
MediaMVP Rev 2.05 do not connect to SageTV 5.04 | ässo | SageTV Media Extender | 22 | 09-22-2006 11:09 PM |
Hauppauge Unveils Wireless MediaMVP for Home Networks | rmbu | SageTV Media Extender | 3 | 01-13-2006 04:17 AM |
MediaMVP: switch from Sage client to Hauppauge menus for avi? | wjfrederick | Hardware Support | 2 | 11-10-2005 10:39 AM |
