Old 02-15-2004, 10:33 PM
salsbst's Avatar
salsbst salsbst is offline
video proc amp control: do they work with recent Haup drivers?
I'm not convinced that the Capture Color Calibration feature is working on my system.... I see no change as I edit the settings. I'm using 2 250s running Haupp drivers #22035.
Old 02-15-2004, 11:57 PM
White94Cobra's Avatar
White94Cobra White94Cobra is offline
I thought I was going crazy... I couldn't notice any difference between the settings. For now I just use the video card settings to adjust brightness/contrast/saturation. Unfortunately that messes up watching DivX movies.
Old 02-16-2004, 10:00 AM
salsbst's Avatar
It also seems that modifying these values sometimes causes the overlay to get fouled up (I end up with a black screen on live tv).
Old 02-16-2004, 07:08 PM
salsbst's Avatar
This is my current "biggest issue."
The setting on which my 2x250s are stuck is horrendous. I'm wondering whether:
a) the problem is really stemming from recent Haupp. drivers
b) if so, how far back should I go to get back this feature; or
c) if not, what else might be causing this.
Can those who have verified that the calibration controls work on 2.0.12 post their driver version numbers?
Tanks a million,
Stuart
Old 02-16-2004, 08:45 PM
mlbdude's Avatar
mlbdude mlbdude is offline
I am using 21288 and it seems to be working fine.
Old 02-17-2004, 01:53 PM
salsbst's Avatar
Thanks mlbdude.
Hmm. Not exactly a statistically significant sample so far. I suppose I may try 21288 tonight since I've just discovered that I'm going to need to swap motherboards. February 04 is going to go down in my personal history as the month I spent wrestling with Hauppauge drivers.
Old 02-18-2004, 09:35 PM
mikejaner's Avatar
I just changed the calibration settings using the latest drivers from SHS's site, and all is well.
mikejaner
Mike Janer
SageTV HD300 Extender X2
Old 02-18-2004, 10:07 PM
Deadbolt's Avatar
Deadbolt Deadbolt is offline
I have 1.8.22037 with SageTV 2.12b and my colors look great.
Deadbolt
Old 02-23-2004, 02:01 PM
salsbst's Avatar
I just rebuilt my machine and went with 22020. Still no ability to calibrate.... which leads me to believe that it is not a matter of the drivers but something gone awry with Sage's ability to set the values.
Old 02-23-2004, 02:06 PM
mlbdude's Avatar
I would submit a bug report to be sure. Put a link to this thread in there too. This is not a good problem to have come up. I love the new controls .
Old 02-28-2004, 08:18 AM
salsbst's Avatar
I just found out it works on the client but not the server!?
This is a bit unfortunate. Makes it very difficult to calibrate to Avia via an external DVD-ROM
Old 02-28-2004, 08:48 AM
salsbst's Avatar
And now I can't seem to get to the s-video encoder in the calibration settings. It keeps showing me the RF cable from the other 250. Argh!
