Old 03-31-2008, 06:54 PM
cgreenle's Avatar
cgreenle cgreenle is offline
High CPU w/ Live TV as compared to BTV
I'm evaluating moving from BTV and I must admit everything is pointing to STV except one thing. Watching only Live TV in BTV I run ~17-20% CPU usage, in STV it runs ~50-60% on SageTV.exe.
The menus seem to drag from one item to the next.
I've searched several threads and have yet to find a solution or even pinpoint the cause.
Here are some specs and settings:
SageTV v6.3.10
SageMC v6.3.7a
Server 2003 RC2
AMD 64 X2 6000+
2gb Ram
M2N32-SLI MB
160gb Sata (Recording Drive)
3tb Raid 5 (Rocketraid 2320)
Nvidia GeForce 7600 GS
HDHomeRun
Full Hardware Acceleration
Video Renderer = Overlay
Mpeg 2 Decoder = Cyberlink Video also tried SageTV Decoder
I don't know what else might be helpful. Please, I appreciate any help or insight you might offer.
Old 03-31-2008, 07:19 PM
Brent Brent is offline
Something isn't right there. CPU usage should be about the same. Let me think about it and I'll see if I can come up with anything to investigate.
Are you running SageTV in Service mode?
OS: XP, Vista, or what?
Try a few additional video decoders just in case
What audio decoder are you using?
Old 03-31-2008, 07:31 PM
cgreenle's Avatar
Service Mode
Server 2003 RC2
AC3Filter
I will try other video decoders, any suggestions?
Old 03-31-2008, 09:33 PM
cgreenle's Avatar
Same result..... ~50% on SageTV.exe
It's all about the playback. When no video is playing it hovers next to nothing. What does BTV use to decode mpeg2 video?
Just for fun I played some Xvids through SageMC.....The CPU ran at about ~10%.
Old 03-31-2008, 10:06 PM
toricred's Avatar
toricred toricred is offline
With the Sage decoder you need to enable DVXA for hardware acceleration. I vaguely recall that when Sage is installed it sets the Sage video decoder so high that no other encoder is used even if you specifically tell it to.
Old 03-31-2008, 10:07 PM
toricred's Avatar
It looks like they fixed the time stamp issue, please see my post above.
Old 04-01-2008, 11:42 AM
Just for kicks don't change anything except do change the audio filter just to see if it makes a difference. I seem to remember AC3 causing an issue (a fixable one). I might be wrong, but give it a shot at least and report back
Old 04-01-2008, 11:59 AM
cgreenle's Avatar
Changing the Audio Decoder didn't seem to make any difference.
I took a look at process explorer and it seems with SageTV decoder selected, mpegdemux.ax seems to be hogging the CPU. With Cyberlink Video it's clvsd.ax....
I don't really know if that helps or not....
Old 04-01-2008, 12:06 PM
Can you give VMR9 and default mpeg2 decoder a try?
Grrr. SageTV Forums are taking that time shifting a bit too far again so the posts are out of order. Anyhow, just in case you missed it toricred has a good suggestions:
Old 04-01-2008, 03:13 PM
cgreenle's Avatar
That didn't seem to make any difference either.
Old 04-01-2008, 03:20 PM
It depends on your setting in BTV. Go into settings and see what video decoder you have set up there.
Old 04-01-2008, 03:40 PM
cgreenle's Avatar
SnapStream Video/SP Decoder
Old 04-01-2008, 05:47 PM
cgreenle's Avatar
Alright, To show my frustration....I completely reloaded STV from scratch. (just uninstall and reinstall didn't work)
I avoided this because I had such a hard time setting up the HDHR but this time it was much faster. I watched the CPU the whole time I made changes and so far.....
I'm running at ~10-15% CPU on Live TV!!!
Thank you so much for your help Brent & toricred!! I'll keep you posted if this happens again.
Old 04-01-2008, 06:10 PM
Great news
Now I wish I understood what was going on behind the scenes, but the fact its working as it should is good. Now take it slow - don't pile on a bunch of plugins until you explore and get things working your way.
SageTV on Windows Server 2003, high cpu after video capture HeeZy SageTV Software 5 08-14-2009 01:26 PM
R5000MOD CPU Utilization/stuttering jmv Hardware Support 11 03-20-2008 03:10 AM
HD Live TV Choppy with CPU 80-100% using HD100 warkeke SageTV Media Extender 4 03-15-2008 11:06 AM
High CPU usage multiple tuners and other issues carlgar SageTV Software 0 11-14-2003 01:18 PM
High CPU load, corrupt wiz.bin file feared with 1.4.7 bling_bling_vr6 SageTV Beta Test Software 3 08-14-2003 12:42 PM
