Old 08-16-2010, 08:56 PM
timg11's Avatar
timg11 timg11 is offline
Visual file location info for Recordings List?
It would be very helpful to have a visual "clue" of where a show is located on disk when viewing the Recordings list.
I expressed my opinion that the practice of merging all drives and folders into the "Recordings" list is non-intuitive in this thread (compared to providing the option to limit it to the one SageTV recording folder) .
For those of us that have a "Working drive" for SageTV shows, and a separate "Archive drive", the management of file locations would be easier if it was easier to see a show's location at a glance.
Is anyone aware of an add-on or plug-in that would allow the shows in the All Recordings list to be color-coded based on which drive they are located on? It is inconvenient to have to go several levels into the menus and scroll around to see the recording details.
HD300 extender with (2020 New Build) SageTV 64 bit V9.2.2.903 (service mode), Running on Windows 10 (64 bit), Intel Core i7-10700K CPU, 16G RAM, GIGABYTE Z490 UD motherboard. NVidia GTX1650 Super; Viewsonic LCD on one output and Mitsubishi WD57734 HDTV via DVI/HDMI on other output. HDHomeRun HDHR5-4US tuner, Hauppauge "Siena" 1512 HD-PVR2 connected to Cisco Cable modem from Spectrum, tuned with USB-UIRT.
Transcode File To Network Location? bigo93bronco SageTV Media Extender 6 12-05-2009 04:40 PM
recordings location optimization bbig119 SageTV Software 2 12-03-2008 07:44 AM
V6.1.7 Client - File Path not shown on Copy Media from File function directory list tawpgk SageTV Beta Test Software 3 04-17-2007 11:05 PM
Best way to change location of recordings? Naylia SageTV Software 2 11-15-2006 01:39 PM
