USBUIRT & exvu4700
hello all, i have a usb uirt (without 56khz) and an expressvu 4700 settop box.
I think this is similar to the dishnet 4700. I cannot get sage to properly learn the codes from the 4700 remote. In the past, sage has reliably learned the codes to many other remotes I own. I am thinking the 4700 remote may operate at 56Khz... and this is why my USBUIRT cannot properly learn the codes. What I am seeing is that sage and the usbuirt fails on 3 or 4 of the channel numbers 0-9... the numbers it fails to learn on are different everytime i run the relearn command. Furhtermore, after repeated attempts, it eventually reports that the code has been learned correctly... however, when sage tries to do a channel change it fails... the channel is either not changed at all or is the wrong number. If this is a 56khz problem... and my usb uirt doesnt have a 56khz sensor... surely someone out there has the required codes for the usb uirt... my understanding is the usbuirt can emit at 56khz... it just cannot receive. I read that a USBUIRT can learn 56Khz codes... and can emit them... it jsut cant "Receive" them... but it can learn them. I have no idea why this isnt working... very frustrating anyone?
XP Pro SP2, P4 2.6 ghz, 1GB RAM, 2 X 80GB seagate serial ATA barracuda HDDs,2 X 160 GB samsung silent parallel ATA HDDs, antec sonata v1.1, msi gforce 6600gt vivo, hpage pvr150, sagetv v5, harmony remote, hauppauge media mvp, USB UIRT, Bell Expressvu Last edited by aoehlke; 09-06-2005 at 01:56 PM. |
