SageTV Linux Discussion related to the SageTV Media Center for Linux. Questions, issues, problems, suggestions, etc. relating to the SageTV Linux should be posted here. |
Linux or Windows? Which to buy?
Hi all,
I am sold on Sage TV but I am now wondering if I should choose the Linux or the Windows version? I prefer Linux as I find it more stable as a server (who cares about the Outlook Express patch when you use Windows as a PVR server?) ![]() I intend to deploy Sage TV on a backend server (Dual Xeons, 4GB RAM, RAID0 120GB disks and Hauppauge PVR-500MCE) and use it with a wireless Media Extender. Is there feature parity between the Windows and Linux version? What about support? Comments? Thanks Martin |
Hi Martin,
In your case I'd recommend looking into Windows Home Server. Sage has a version specifically designed for it, and it provides all the features of the regular Windows version of Sage with the robustness of a true server OS. To me, Linux works reliably (one of my home servers is based on Linux) but that is more due to the fact that it has limited hardware suppport (read mature drivers for that reduced selection of compatible hardware) rather than something inherently superior about it's architecture. 'If' you use good quality hardware and don't play 'musical drivers' then a Windows box will be just as reliable. -PGPfan Quote:
Sage Server: Gigabyte 690AMD m-ATX, Athlon II X4 620 Propus, 3.0 GB ram, (1) VistaView dual analog PCI-e tuner, (2) Avermedia Purity 3D MCE 250's, (1) HD-Homerun, 1.5 TB of hard drives in a Windows Home Server drive pool, Western Digital 300GB 'scratch' disk outside the pool, Gigabit LAN Sage Clients: MSI DIVA m-ATX, 5.1 channel 100w/channel amplifier card, 2 GB ram, , (1) Hauppauge MVP, (1) SageTV HD-100 Media Storage: unRAID 3.6TB server |
My windows Sage install is pretty reliable. I only reboot it once a month, and that is just for Patch Tuesday. If you don't have tons of junk installed, and just the important stuff, a windows box can be pretty good as a server.
My parent's Sage box goes months on end between reboots. It only gets rebooted when I stop by and see that there are windows updates that could be installed (I don't have automatic updates setup). As for support, A windows license gets you Official Support from Sage and the linux license is designed for OEMs, so no Official Support. Not all the Sage plugins out there are linux or Mac compatable. Not sure if the supported tuner list is as big for the linux build.
- Jack __________________________________________ Server: AMD Phenom 9750, 2GB RAM, 2 Hauppauge PVR500, 1 Firewired DCT6200, 1 HDHomerun tuning 2 QAM channels, Vizio 37" HDTV LCD, 1 USB-UIRT Clients: 1 MediaMVP, 1 Placeshifter Client, & 1 SageTV Client. |
And while there may be out-of-the-box feature parity between the Windows and Linux versions of Sage, the vast majority of third-party add-ons are developed for Windows. Do be aware, though, that the Windows and Linux versions are separate products with separate licenses. You can't buy a Windows license and then change your mind later and use it on Linux (or vice versa). So be sure before you buy that you're making a choice you can live with.
-- Greg |
Oh, and what hasn't been mentioned, unless something has been changed, there's no "official" support for individuals running SageTV OEM for Linux. Not saying you won't get any, but something to consider... |
I switched from windows to linux. I find the QAM support is more extensive and hd runs better. I also like to play around with other servers too which linux is more flexible imho.
B |
It depends
I would argue that it all depends on what you're comfortable with and what else you plan to do with the box. I have SageTV running on the same Linux box as Asterisk, Icecast, MPD, pyTivo, Cidero, and Slimserver. You asked the right question when you queried about feature differences, though the major differences are going to be the additional software you plan to run.
I'd recommend making a list of what features/capabilities/services you want to run and then take a look at what software on which OS best suits your needs. Otherwise, this just becomes a my religion is better than yours argument. - joat |
In my oppinion, stick with what you know. If you are windows person that sometimes tries linux for kicks, and then goes back to windows.... don't run sage on linux. The biggest problem that I find with windows users going to linux is that they give upt he first time something doesn't work. The same is true for my linux friends that complain about windows not working right
![]() As for hardware support. I personally find that I have better sucess lately in linux than windows. My DVB-S card just works, no driver install disk required. My pvr-usb2 device works, no driver install disk required. I was blown away the other day when I plugged in my canon sd1000 camara, and a dialog appeared asking me to copy files from the camera, again, no driver disk required. (This is a Ubuntu machine) As for sage support in linux.... even though there isn't any offical support, I've been very impressed with their responsiveness and quality of solutions. If you are switching to a new OS, plan on some pain... but sometimes the switch is worth it ![]()
Purchasing Windows and Linux versions? | morikaweb | General Discussion | 19 | 05-22-2007 09:05 PM |
Linux VS Windows questions? | dpackham | SageTV Beta Test Software | 8 | 12-15-2006 07:20 AM |
Linux version install errors | rschellenberg | SageTV Linux | 4 | 08-06-2006 09:16 PM |
Linux server & Windows client: comskip | kn4ppst3r | SageTV Customizations | 0 | 02-09-2006 04:32 PM |
Windows -> Linux migration question | pciccone | SageTV Linux | 8 | 01-16-2006 01:00 PM |
