Old 05-04-2008, 09:09 AM
TomB TomB is offline
How do I capture Video
I have installed SageTV with a TV tuner card which works just fine. I also have a Plextor M402U video capture device. Both of these devices are setup as sources in SageTV.
Now, I want to record some video using the M402U. How the heck do I set SageTV to record from that device vs. the TV tuner?
Tom
Old 05-04-2008, 11:09 AM
GKusnick's Avatar
GKusnick GKusnick is offline
It can be done with Sage by setting up a dummy channel lineup on that source and using a timed recording to capture video from one of those dummy channels. But for things like transferring VHS to your PC, it's probably simpler to use the software that came with your device.
-- Greg
Old 05-04-2008, 02:04 PM
That's what I was afraid of. I do have other software that will capture video from it. So I guess that's the solution.
Thanks for the help, Tom
SageTV V6.3.2 Beta is Available! Narflex SageTV Beta Test Software 0 11-21-2007 07:08 PM
Black screen and no audio on Client shatter SageTV Software 7 02-21-2007 08:41 PM
Only get video with default renderer... bash1979 SageTV Software 4 11-14-2005 01:25 PM
