Old 12-29-2008, 08:23 PM
AJ Bertelson AJ Bertelson is offline
AnyDVD rips not playing in sagetv
Picked up AnyDVD this weekend before they went to a subscription based payment system and I am unable to get my DVD rips through AnyDVD to work.
If I rip the DVD through DVDdecrypter it works with sagetv. I know it's probably something simple I am missing but I unchecked the option to remove the adverts and skip rite to the title screen.
Any ideas?
Old 12-29-2008, 08:26 PM
How are you making them? Copying the files? Using the built in "rip" function?
Old 12-29-2008, 09:16 PM
Rip video to hard disk is how I am doing it.
The default options are selected.
Old 12-29-2008, 09:21 PM
Make sure it's not sticking the rip in a wierd subdirectory of where you told it.
Old 12-29-2008, 09:32 PM
tedson tedson is offline
It is working for me. I am using anydvd with dvd shrink 3.2 to make isos. Then I load the isos with virtual clone drive and copy the folders out of the iso file to a subdirectory on the server. None of the extenders HD100 or 200 have any problems playing the, but you have to make sure the main folder the rips are in is both shared and that the path to the folder is in the form //machine/dvdfolder instead of c:/dvdfolder or the extenders wont play the dvds.
Old 12-29-2008, 09:41 PM
What's the purpose of the ISOs, that seems completely unnecessary, DVD shrink will rip directly to a folder....
Old 12-29-2008, 10:23 PM
HelenWeathers's Avatar
I use AnyDVD HD (paid version, not sure that matters) to rip all my Blu-rays. I then use TSMuxer GUI to convert only the movie and selected sound tracks to a .ts file (generally 30% to 50% smaller size than the movie folder). I do downmix DTS HD to DTS (and include the AC3 2 channel track for DTS Blu-ray rips) and DD True HD gets downmixed to DD 5.1. All the downmixing is for compatability with my SageTV Clients and HD 200.
I've only done about 30 rips so far, but all play without issue.
Old 12-29-2008, 11:02 PM
yeah no weird directories and I can now report that a dvd rip of dvddecrypter doesn't work.
Example,
Casino royale ripped with both dvd decrypter and anydvd doesn't play back in sagetv. I get a error in playback now(there was a problem accessing your file system), using sagetv codec.
Old 12-29-2008, 11:19 PM
GTwannabe's Avatar
GTwannabe GTwannabe is offline
AnyDVD ripper appends the disc title to whatever path you tell it to use. Assuming you can find them, they will play just fine in SageTV.
Intel NUC SageTV 7 server - HDHomeRun PRIME - 2TB iSCSI ReadyNAS storage
Intel i3 HTPC SageTV 7 Client - Win 7 x64 - Onkyo TX-674
Old 12-30-2008, 07:34 AM
briands briands is offline
If I recall, the default Sage video decoder will not decode DVDs. You need to go to Setup/Detailed settings/ DVD and set the DVD decoder filter to something OTHER THAN SageTV MPEG decoder.
Example,
Or it might be how you have permission set up to your shared folder. Can you play other files from the same drive?
Old 12-30-2008, 09:48 AM
Yes I have the microsoft mpeg decoder as DVD and the multimedia codec.
I did change something around though as I finally got my terrabyte and a half drive hooked up to my sagesver that runs xp home. The files were originally stored in mydocuments video folder on my workstation computer that ran XP pro with the mydocs directory was shared out and this setup worked.
After the drive got installed I transfered mydocs folder over to the sageserver and this was where I experienced my problems. All of the video files except the DVD rips work. Music and photo files also work.
edit-I just verified through changing the import directories that the exact same DVD rip will play from the XP pro workstation(through sage of course) but will not play through the sageserver drive that is running XPhome.
Old 12-30-2008, 08:47 PM
Ryokurin's Avatar
Ryokurin Ryokurin is offline
Send a message via ICQ to Ryokurin Send a message via AIM to Ryokurin Send a message via Yahoo to Ryokurin
Its just basically to make it easier to archive. One file, so you can basically take a image program like virtual clone drive, set it to take isos and just double click to mount.
One big thing to note however, making a iso does not completely clean the disc, so while it may be playable, it can still potentially throw some programs like dvd shrink due to the partial protection still on the disc. Ripping to a folder cleans the disc completely.
One thing I would try is to see if any other program will play the ripped files. Try something like zoom player or media player classic (but toggle its built in codec to see if its a wrong directshow setting, or something else)
Old 12-30-2008, 09:19 PM
I thought you said you were Disc->ISO->Virtual Drive->DVD Shrink->Folder, why not just Disc->DVD Shrink->Folder?
Old 12-31-2008, 08:16 AM
moamoa's Avatar
moamoa moamoa is offline
This is pretty much what I want to do. Is there a guide at all the shows the apps required and step in order to do this?
Cheers.
SageTV Server 7.0.23 - SageTV Client on 50" Plasma - HD100 Extender on 42" Plasma - HD300 on 92" Espon EH-TW3200 Projector 5.1 DB/DTS on all clients.
Old 12-31-2008, 09:42 AM
Sorry you are right the ISOs aren't a must. I keep them in a separate backed up archive and use them to burn copies of the movies for the car dvd player. It gets so hot in there that I have had DVDs warp more than once. The folders go into the drive sage uses. I wish sage would play the ISOs directly, but such is life. Since I use both I keep both, but going to ISO before going to folders is not a "must" step.
Old 01-01-2009, 06:32 AM
Example,
Reassign ownership or permissions to that folder. It came from another machine and the current ID can't access the rips.
Old 01-07-2009, 03:33 PM
Patilan Patilan is offline
Regarding ISO files, I have two curious observations:
1. If you drag-drop your ISO file directly on top of SageTVPlayer.exe, it plays the movie without a problem.
2. If you add ".iso" to "seeker/video_library_import_filename_extensions=" in "Sage.properties", import the ISO in your video library, and click "View Video Detail", you'll see that Sage correctly recognizes what's inside that file. It would say for example:
1 hour 37 minutes
File: [C:\DVDs\John and Jane's Wedding.ISO]
Format: MPEG2-PS[MPEG2-Video 16:9 480i@29.97fps,
AC3/384Kbps@48kHz 5.1]
File Size: 3.04 GB
...all perfectly correct! But if I try playing it from there, SageTV aborts with "sage.PlaybackException: ERROR..."
The above two observations make me think that there must be a relatively easy way to make SageTV play ISO files.
Maybe some of the more knowlegeable guys here can come up with some ideas?
Patilan
Old 01-07-2009, 03:38 PM
SageTV (PC) can't play ISOs. Only folders. The Extenders can however play ISOs.
Old 01-07-2009, 04:45 PM
Stanger, I am aware of that. But my question was, if the UI can see correctly what's in the ISO, and if sagetvplayer can play the ISO, then what's the holdup?
I mean, so many players (many of them free) can play ISO's, why should SageTV not be able to play ISOs? I think that it would be a useful new feature for SageTV, with minimal programming effort on Sage's part.
Patilan
Old 01-07-2009, 04:58 PM
Originally Posted by Patilan View Post
Stanger, I am aware of that. But ny question was, if the UI can see correctly what's in the ISO, and if sagetvplayer can play the ISO, then what's the holdup?
There's no Dshow splitter for an ISO.
Almost nothing can play ISOs. Only VLC and XBMC (and only on the xbox?), not TheaterTek, not Zoomplayer, PowerDVD, WinDVD, VMC, etc. Everything else that "supports" them, mounts them to a virtual drive or requires mounting them to a virtual drive.
Playing a recorded show locks up PC rswoods SageTV Software 3 12-16-2008 09:36 AM
Playing back Bluray, how do you do it. m1abrams General Discussion 3 11-17-2008 12:32 PM
Blu Ray playing blues... Big Jeff General Discussion 6 10-31-2008 06:15 PM
Playing live TV through the HD Extender brboot SageTV Media Extender 1 10-14-2008 11:27 AM
HD-100 hangs playing DVDs rips rdefino SageTV Beta Test Software 2 06-03-2008 09:21 AM
