6.5.6 - Not quite ready for prime time yet
I have been running 6.4.8 for awhile now (it's been very stable).
I tried RC 6.5.6 last night for the first time, and within a few minutes, the SageTV client on my PC totally locked up (not even a spinning circle) while changing a channel. I don't know if this also occurs on my HD100 Media Extender, since I never got that far. I'm back to 6.4.8 again for now ... |
A beta release not ready for prime time, no kidding? The whole point of betas are for testing and ironing out the bugs. So if you saved the debug logs, you can send it to SageTV so they can figure out the problem you are having.
Mayamaniac - SageTV 7.1.9 Server. Win7 32bit in VMWare Fusion. HDHR (FiOS Coax). HDHR Prime 3 Tuners (FiOS Cable Card). Gemstone theme. - SageTV HD300 - HDMI 1080p Samsung 75" LED. |
Well, I see both of your points.
First, 6.5.6 is supposed to be the release canidate and that to me means Sage staff considers it "ready for primetime". And many times, as in 6.4.8 there were no changes between the RC and the public version. Second, running it once and locking up does not mean it's not ready either unless it is consistent which you did not mention. However, if you can reproduce this error, please report it so that it does not get released with this problem. |
I've been running 6.5.6 since the day it was released (server as well as client, STV only) and have only seen the spinning circle twice for a couple of seconds each. It was after a long FF and I just attributed it to me jumping ahead of what was already buffered. One other issue I had only once (and am unable to recreate so far) was a freeze after a couple of jumps ahead. That was cured by a short rewind. I do have logging on so if the freeze happens again I'll report it.
Server: SageTV 9, Win10/32, Intel DP55KG Mb, Intel QC i5 2.66GHz , 4GB 1333MHz DDR3 SDRAM, 2 Hauppauge 2255s for 4 OTA ATSC tuners, HDHRPrime w Comcast, 3 STP-HD300s 20101007-0 firmware, nVidia Shield. Java v7u55. Plugins:SD EPG, OpenDCT |
If my wonderful wife found out that I was foolin' with "That da*ned SageTV again" instead of doing work, I would have had to do the rest of the SageTV debugging from the nearest hotel room. ![]() |
If you look hard enough on the forum, I'm sure you can find all sorts of lockup problems that people have with 6.4.8 also. Now does it means it wasn't ready for primetime?
RC or not, as long as it in the beta software section, it is a beta. In dealing with betas, unless you have spare time to deal with software problems, then you should not install it over your stable system. Definitely, you should not install a beta if you have important scheduled recordings coming up. I'm still running 6.5.5 because I don't have time to deal with 6.5.6 just incase it has problems. I might just wait for the release version which I guess will be in a week or so.
But don't you pretty much need one of the 6.5 betas if you have an HD-200?
Only if you do not have a Placeshifter license. As we know placeshifter license are floating and any device can use them. If you have a HD100 the HD200 will work with version 6.4.8 they just can not run at the same time.
Well, I reinstalled RC 6.5.6 for a second go at it, and the PC interface locked up again within the first few minutes of use.
In addition, the response on the user interface seemed considerably slower - I saw lots of spinning circles as I moved around and changed channels. I put in a bug report last week, and am waiting to hear back from SageTV tech support. I am also back at 6.4.8 for now. AzJazz |
I too am seeing A LOT of spinning circles and sluggish behaviour. Even some crashing to the desktop once every day or two. I'm just living with it for now until the next update!
Win7Pro, SageTV v6.6, SageMC, Intel E6850, 2048MB DDR2, , ATI4750, LG BR/HDVD/DVD-Rom,1xHDHR, 1xPVR-1600 (1x DirectTV , 1x Comcast Analog Cable, and 3x OTA Digital), USB-UIRT, and Harmony 300 Remote + 1 MVP Extender + 1 PC Client. |
For whatever it is worth, RC 6.5.7 is working much better for me than RC 6.5.6, and seems as stable as 6.4.8 so far (1 day and counting ...
Lost my seek bar, time scroll bars in 6.3.8. Also t9? | horseflesh | SageMC Custom Interface | 3 | 10-21-2008 01:49 AM |
Request for recommendation, first time SageTV setup | tbizzy | General Discussion | 11 | 10-17-2008 01:06 AM |
I'm having some time issues....not DST related | setherd | SageTV Software | 16 | 11-19-2007 02:47 PM |
Sage time off 4 hours but system time is fine? | dvd_maniac | SageTV Software | 3 | 10-25-2007 01:21 PM |
Playback Stutters, Pauses, Speeds up, then it's fine? | tangfj | SageTV Software | 23 | 03-22-2006 10:54 AM |
