Can I get a client to choose SD encoder over HD encoder?
I have NYC local Time Warner clear QAM channels on the same channel lineup as SD local channels from a Time Warner STB. Clear QAM is input through the digital tuner on a Hauppauge 1850 card and the SD through the same card's S-Video.
This setup works fine through a HD 300. Sage uses the HD Clear QAM unless the encoder is in use, then it uses the STB's SD. The problem is that I would like to force a client on a single core 1.8Mhz PC to choose the local SD channels as it doesn't have enough "horsepower" to play the HD mpg files. I've tried setting encoder merit on the client's properties file (on the client machine) but Sage still picks the HD over the SD recording. I have a HD PVR for HD channels from the STB and I guess I could use the local HD channels from it for viewing via the HD 300 and map only the SD local channels (for client viewing), but I would miss the clear QAM mpg files, especially for quick comskip processing (much quicker than the TS files.) Any ideas? |
Encoder number graphic shows wrong encoder being used | jpaddock3000 | SageMC Custom Interface | 11 | 02-05-2009 02:29 PM |
Which encoder is '1', '2', '3' etc... | Stuntman | SageMC Custom Interface | 13 | 02-19-2008 11:22 AM |
network encoder stutters but ok on the encoder pc | stryker | SageTV Software | 4 | 01-09-2008 02:28 PM |
Encoder card at client? | Steve52 | Hardware Support | 2 | 05-04-2006 10:46 AM |
How do I get Sage recorder setup as an encoder on a client? | carlgar | SageTV Recorder Software | 2 | 01-29-2004 11:16 PM |
