Old 07-27-2017, 07:42 AM
jbuszkie's Avatar
jbuszkie jbuszkie is offline
OpenDCT stopping..
Twice now I've noticed that OpenDCT was stopped. After looking through the logs I saw this:
INFO   | jvm 2    | 2017/07/24 07:39:58.102 | 07:39:58.053 [ChannelManager-57] INFO  HDHomeRunChannels - Connecting to HDHomeRun using the URL 'http://192.168.2.92:80/lineup.xml'
INFO   | jvm 2    | 2017/07/24 07:49:51.789 | [GC pause (G1 Evacuation Pause) (young) 84M->9695K(128M), 0.0039382 secs]
ERROR  | wrapper  | 2017/07/24 08:01:58.031 | JVM appears hung: Timed out waiting for signal from JVM.
INFO   | jvm 2    | 2017/07/24 08:02:00.586 | 08:02:00.486 [NIOHTTPProducerImpl-19742:DCT-HDHomeRun Prime Tuner 13115570-0] WARN  NIOHTTPProducerImpl - An exception occurred while receiving data => java.io.IOException: Connection reset by peer
INFO   | jvm 2    | 2017/07/24 08:02:00.586 | 	at sun.nio.ch.FileDispatcherImpl.read0(Native Method)
INFO   | jvm 2    | 2017/07/24 08:02:00.586 | 	at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39)
INFO   | jvm 2    | 2017/07/24 08:02:00.586 | 	at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:223)
INFO   | jvm 2    | 2017/07/24 08:02:00.586 | 	at sun.nio.ch.IOUtil.read(IOUtil.java:192)
INFO   | jvm 2    | 2017/07/24 08:02:00.586 | 	at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:380)
INFO   | jvm 2    | 2017/07/24 08:02:00.586 | 	at opendct.video.http.NIOHttpDownloader.read(NIOHttpDownloader.java:218)
INFO   | jvm 2    | 2017/07/24 08:02:00.586 | 	at opendct.producer.NIOHTTPProducerImpl.run(NIOHTTPProducerImpl.java:263)
INFO   | jvm 2    | 2017/07/24 08:02:00.586 | 	at java.lang.Thread.run(Thread.java:745)
INFO   | wrapper  | 2017/07/24 08:02:00.587 | Wrapper Process has not received any CPU time for 75 seconds.  Extending timeouts.
INFO   | jvm 2    | 2017/07/24 08:02:09.597 | 08:02:09.504 [NIOHTTPProducerImpl-19742:DCT-HDHomeRun Prime Tuner 13115570-0] ERROR NIOHTTPProducerImpl - Producer thread created an unexpected exception => java.nio.channels.AlreadyConnectedException
INFO   | jvm 2    | 2017/07/24 08:02:09.597 | 	at sun.nio.ch.SocketChannelImpl.ensureOpenAndUnconnected(SocketChannelImpl.java:610)
INFO   | jvm 2    | 2017/07/24 08:02:09.597 | 	at sun.nio.ch.SocketChannelImpl.connect(SocketChannelImpl.java:621)
INFO   | jvm 2    | 2017/07/24 08:02:09.597 | 	at opendct.video.http.NIOHttpDownloader.connect(NIOHttpDownloader.java:88)
INFO   | jvm 2    | 2017/07/24 08:02:09.597 | 	at opendct.video.http.NIOHttpDownloader.connect(NIOHttpDownloader.java:65)
INFO   | jvm 2    | 2017/07/24 08:02:09.597 | 	at opendct.producer.NIOHTTPProducerImpl.run(NIOHTTPProducerImpl.java:229)
INFO   | jvm 2    | 2017/07/24 08:02:09.597 | 	at java.lang.Thread.run(Thread.java:745)
INFO   | jvm 2    | 2017/07/24 08:02:09.597 | 08:02:09.504 [NIOHTTPProducerImpl-19742:DCT-HDHomeRun Prime Tuner 13115570-0] INFO  NIOHTTPProducerImpl - Producer thread has stopped.
INFO   | jvm 2    | 2017/07/24 08:02:28.816 | Wrapper Manager: The Wrapper code did not ping the JVM for 30 seconds.  Quit and let the Wrapper resynch.
STATUS | wrapper  | 2017/07/24 08:02:28.816 | JVM requested a restart.
INFO   | jvm 2    | 2017/07/24 08:02:38.426 | 08:02:38.331 [SageTVManagerShutdown] INFO  Main - Stopping all SageTV socket servers...
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.333 [NanoHTTPDShutdown] INFO  Main - Stopping web server...
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.333 [PowerMessageManagerShutdown] INFO  Main - Stopping power messages...
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.333 [DiscoveryManagerShutdown] INFO  Main - Stopping device discovery services...
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.334 [NanoHTTPDShutdown] INFO  NanoHTTPDManager - Stopping webserver on port 9091...
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.334 [SageTVTuningMonitor-66] INFO  SageTVTuningMonitor - Tuning monitor thread interrupted.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.334 [Shutdown] INFO  Main - OpenDCT has received a signal to stop.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.334 [ChannelManagerShutdown] INFO  Main - Stopping all channel update threads...
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.334 [PowerMessageManagerShutdown] WARN  LinuxPowerMessagePump - System power state messages are currently not implemented for Linux.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.335 [SageTVSocketServer-67:9000] INFO  SageTVSocketServer - Stopped listening on port 9000...
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.336 [SageTVManagerShutdown] INFO  SageTVManager - The capture device 'DCT-HDHomeRun Prime Tuner 131953B8-1' is being unloaded.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.337 [ChannelManagerShutdown] INFO  ChannelManager - Saving the channel lineup 'dct_hdhomerun'.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.337 [Shutdown] INFO  Main - Saving current configuration...
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.340 [SageTVManagerShutdown] INFO  SageTVManager - The capture device 'DCT-HDHomeRun Prime Tuner 131953B8-0' is being unloaded.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.342 [SageTVManagerShutdown] INFO  SageTVManager - The capture device 'DCT-HDHomeRun Prime Tuner 131953B8-2' is being unloaded.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.343 [SageTVManagerShutdown] INFO  SageTVManager - The capture device 'DCT-HDHomeRun Prime Tuner 13115570-2' is being unloaded.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.344 [SageTVManagerShutdown] INFO  SageTVManager - The capture device 'DCT-HDHomeRun Prime Tuner 13115570-1' is being unloaded.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.345 [SageTVManagerShutdown] INFO  SageTVManager - The capture device 'DCT-HDHomeRun Prime Tuner 13115570-0' is being unloaded.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.345 [SageTVManagerShutdown] INFO  HDHRNativeCaptureDevice - Capture device was already locked.
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.347 [UPnPDiscovery-40] INFO  UpnpManager - UPnP discovery thread was interrupted => java.lang.InterruptedException: sleep interrupted
INFO   | jvm 2    | 2017/07/24 08:02:38.427 | 08:02:38.351 [DiscoveryManagerShutdown] WARN  DiscoveryRegistryListener - Before UPnP shutdown, the registry did not contain any devices.
INFO   | jvm 2    | 2017/07/24 08:02:38.627 | 08:02:38.555 [DiscoveryManagerShutdown] INFO  DiscoveryManager - UPnP discovery stopped.
INFO   | jvm 2    | 2017/07/24 08:02:38.627 | 08:02:38.556 [DiscoveryManagerShutdown] INFO  DiscoveryManager - HDHomeRun discovery stopped.
INFO   | jvm 2    | 2017/07/24 08:02:38.627 | 08:02:38.556 [DiscoveryManagerShutdown] INFO  DiscoveryManager - Generic HTTP discovery stopped.
INFO   | jvm 2    | 2017/07/24 08:02:38.627 | 08:02:38.556 [DiscoveryManagerShutdown] INFO  DiscoveryManager - Generic Pipe discovery stopped.
ERROR  | wrapper  | 2017/07/24 08:02:54.946 | Shutdown failed: Timed out waiting for the JVM to terminate.
ERROR  | wrapper  | 2017/07/24 08:02:55.046 | JVM did not exit on request, terminated
STATUS | wrapper  | 2017/07/24 08:02:58.954 | JVM exited in response to signal SIGKILL (9).
ERROR  | wrapper  | 2017/07/24 08:02:58.954 | Unable to start a JVM
STATUS | wrapper  | 2017/07/24 08:02:59.054 | <-- Wrapper Stopped
I've seen a couple times in the log where it said:
 Wrapper Process has not received any CPU time for xxx seconds
Has anyone seen this before? Is there some way to bump it's priority? The only other docker (other than sage) is the crash plan one.
Jim
Old 07-27-2017, 08:32 AM
EnterNoEscape's Avatar
I'm not really getting the big picture here. Please post the entire log.
Need help with OpenDCT on Docker willieb SageTV for unRAID/Docker 5 03-07-2017 07:36 AM
opendct location mechling-burgh SageTV for unRAID/Docker 2 02-04-2017 08:37 PM
OpenDCT and R5000 checkbin Hardware Support 9 12-29-2016 12:54 PM
OpenDCT: Can I use it? SDeGonge Hardware Support 7 02-20-2016 10:27 AM
InfiniTV4 with OpenDCT tomdomm Hardware Support 58 02-03-2016 07:00 PM
