Best way to remove old tuner entries
I run a couple of network tuners, plus I've used a couple of VM's in the past and OpenDCT in a separate docker, so I have A LOT of dead/old tuner entries that show up when I try to add a new tuner.
What is the best/easiest way to remove them? I think in the past I've deleted the mmc/encoders section for each old one, which is a pain to search through all of them while preserving the active ones. I also see a section called RDP/encoder_name_Hauppauge with some dead ones, do these need to be deleted too? Or is there an easier way or just delete one line maybe and the rest go away? Any tips appreciated.
----- AMD Ryzen 5 3600, B450 m/b, 32Gig, lots of disks, Unraid, 2x HDPVR2 tuners, HDHomeRun Prime, HDHomeRun HDHR4 OTA, Windows Live Tuner, SageTV docker, OpenDCT docker, Win8.1 VM, EventGhost |
I agree, I have a bunch of old, dead DCT "tuners" that show up on the system. I need to know this as well!
I just realized I left off the ? at the end of the title. Sorry to those of you thinking I had a great way to do it, but hopefully someone else will come up with one.
That is the easy way to delete them from the sage.properties file.
Channels DVR UBUNTU Server 2 Primes 3 Connects TVE SageTV Docker with input from Channels DVR XMLTV and M3U VIA Opendct. |
It is easier if you use notepad+
I actually did it that way and it wasn't too bad, just being dramatic. Unfortunately my 2 network encoders regurgitate everything so the list filled up again.
I wish you could tell your network encoder instance to only advertise it's native tuners, and not relist everything it sees. I don't need to see the same tuner being offered by 3 different systems, it really confuses and gums up the list.
Just curious - after you remove the unwanted tuner entries, do you lose info about which tuner was used to record a show (when viewing show details)?
--John |
Apparently not. I checked a recording recorded on a tuner that I knew was gone and it still showed that tuner's information.
OK, so a couple of questions:
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.11.5, sagetvopen-sagetv-server-opendct-java11 Docker (version 2.0.7) Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls |
ASRock B450M Pro4 AM4 MB, Ryzen 5 2600 3.4ghz, Crucial Ballistix Gaming 32GB (2 x 16GB) DDR4-3200, EVGA GT 1030SC, WD Black NVMe SSD 250GB, 1x WD120EFAX 12TB, 1x WD80EFAX 8TB, 1x WDBH2D0040HNC 4TB, USB-UIRT, Colossus 2, WinTV-DualHD USB, Windows 11 64bit |
Two log entries in BMT Web UI? | MacDaddy | Batch Metadata Tools | 1 | 12-18-2010 07:04 AM |
Double Entries? | ChaOConnor | Sage My Movies | 5 | 11-09-2010 07:08 AM |
HD300 FAQ entries | Opus4 | SageTV Media Extender | 5 | 09-13-2010 09:15 PM |
entries in .frq file | Sten3danny | Hardware Support | 0 | 07-29-2009 03:12 PM |
No Data entries in EPG | sfisher | SageTV Software | 4 | 03-03-2004 01:21 PM |
