Old 09-14-2022, 04:32 PM
graywolf's Avatar
graywolf graywolf is offline
Why does it change to Timed Record?
Prior, Fox & Friends (3 hrs) was 1x 3hr entry in the EPG. Recently it has changed to 3x 1hr entries. My wife has "padded" the first entry to cover all 3 hrs so it is 1 recording. And then it shows initially as Fox & Friends. But later when she checks (e.g. a couple days out, Friday's setup) it now says Timed Record instead of Fox & Friends.
Anyone know why that is happening and maybe how to fix it until the EPG goes back to showing it as 1x 3hr entry?
Old 09-14-2022, 06:40 PM
I believe that happens when the guide data changes on a manual recording.
Old 09-14-2022, 08:07 PM
tvmaster2's Avatar
yes, I believe that’s correct.
Old 09-15-2022, 08:19 AM
Tiki's Avatar
Tiki Tiki is offline
That’s true. But you usually get a warning message in the message log when this happens. Are you seeing any messages?
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Timed Record Recordings - Where Are They Coming From floyd_2 SageTV Australia/New Zealand 3 12-15-2008 06:59 AM
Question: Is there an easy way to rename a "Timed Record" Soleil SageTV Software 2 07-17-2007 02:59 PM
Timed Recordings don't always record WuphonsReach SageTV Software 0 12-19-2005 11:54 AM
Rename Timed Record rlusignan SageTV Software 4 06-21-2005 12:45 AM
"Timed Record" at Fri 3/5 conflict? salsbst SageTV Beta Test Software 1 02-28-2004 09:49 AM
