Old 10-16-2022, 01:57 PM
Import all Videos as Recordings?
There is a handy feature in BMT for "Import TV Media Types as Recordings". If you place a video into an import directory, and BMT finds TV metadata for it, then it gets added to the Recordings screen (instead of staying in the imported video area).
Is there a way to make sure every imported video gets added as a TV Recording, even if no metadata was found for it?
I spend almost all of my time in the recordings screen so it's a bit cumbersome to go looking in the imports area.
Old 10-20-2022, 03:29 PM
brandypuff brandypuff is offline
I don't think there is.
- James M -
Capture Devices: HDHomerunXTEND, HDHomerunPrime
Old 10-20-2022, 07:33 PM
Might want to add this as a request as I believe jusjoken has plans to update BMT.
Old 10-20-2022, 09:05 PM
tvmaster2's Avatar
So all videos, whether downloads, rips, etc., could appear as recordings? That would be useful
Old 10-21-2022, 01:48 PM
CMT can do this ...
Old 10-21-2022, 02:00 PM
CMT can do this ...
How do you do that? And not one - by one. If you are importing thousands of recordings, how do you have them default to be TV shows rather than Movies?
cannot import some videos peawormsworth SageTV Linux 2 04-27-2011 11:46 AM
TV Recordings in Import Directories are: Imports/Recordings Setting jorton SageTV Beta Test Software 4 09-04-2010 11:08 AM
Can not import videos. Please help. Lenp2005 SageTV Software 2 01-24-2007 02:58 PM
Moving Sage-recorded Videos from Imported Videos to SageTV Recordings esims21 SageTV Software 1 02-05-2005 11:32 AM
