Old 06-05-2011, 08:59 AM
davidjames davidjames is offline
SageTV Client - Java Exception
Before I open a ticket I thought maybe someone has experienced this.
I'm running Server 7.1.7.254 on Windows 7
I installed SageTV client 7.0.23 (with license) on Windows XP Professional
I have Java 1.6.025 installed on the client.
When starting the client
First, the server isn't discovered so I enter the IP address.
After quite a while, I get a Java Null Pointer exception when starting client
I turned off the firewall on the client and opened the correct ports on the server
I have server enabled on the server
Thoughts?
Edit - After creating this it dawned on my that I was using different version on the client and server. I downloaded the beta client and it works fine - lesson learned (again)
Old 06-06-2011, 05:00 PM
kurbo kurbo is offline
Mine started doing the same thing within the last week. The media extenders Hd200 and HD300s all work but not the pc client
An exception occured in Java: swarnold SageTV Placeshifter 0 06-22-2009 08:54 PM
Java Exception mike1961 SageTV Software 0 12-20-2005 06:13 PM
An exception occurred in Java: will_fish SageTV Software 2 11-05-2003 12:49 AM
Beta V1.2.2 Java java.lang Null Pointer Exception hamptonhills SageTV Beta Test Software 1 03-27-2003 12:11 PM
