Old 11-15-2012, 12:01 PM
t4runnr t4runnr is offline
MCE remote
I'm having a weird issue with my MCE remote and my Sage v7 client. I'm also using eventghost.
Anyway, when I boot up my HTPC, it autostarts eventghost and my Sage client. Once its loaded, my remote won't work. None of the buttons show any action. However, once I click on a menu item with the keyboard or mouse, the remote starts to work.
Anyone have any clue what is causing this?
Thanks for your help.
Old 11-15-2012, 04:01 PM
SWKerr SWKerr is offline
Are you using the SageTV plugin for EventGhost?
It really should find the SageTV window if you are using the plugin.
You can also also add a "Find Window" command followed by a "Bring to the Front" command to existing command or new button and it should solve you problem without having to touch the keyboard.
Old 11-16-2012, 05:42 AM
Yes. I'm using the plugin. I'll give your suggestion a try. Thanks.
Old 11-16-2012, 08:57 AM
Make sure you Install 2 plugins to run Sage the ... Microsoft MCE remote Vista / Windows 7 plugin and the Sage plugin.
Old 11-16-2012, 09:56 AM
Thanks. I have both those running as well. Are you saying those plugins alone should do it and that I don't need to do a findwindow event? If so, it isn't happening.
Old 11-16-2012, 10:13 AM
did you setup the sagetv plugin completely assigned a button to each command?
Old 11-16-2012, 12:14 PM
I only assigned buttons to commands that I normally use. Not every button or command is used in my setup.
Old 11-16-2012, 01:17 PM
It appears your Sage window does not have focus when your PC starts. You may want to delay the start of SageTV so that it loads last. Something else is stealing focus.
Old 11-16-2012, 01:27 PM
I never thought of that. That's a good idea. I know in the past on other machines I had, I had a batch file in the startup directory that delayed the start of a specific program. I also know there are startup control programs that can do the same.
If I were to go either route, would I have to disable the autostart in the Sage menu setup?
Old 11-16-2012, 02:29 PM
The Sagetv plugin that comes with eventghost does not require focus it uses sendmessage. Make sure the Sagetv plugin is configured correctly for ether Sagetv or Sagetvclient. I put 5 open windows on top of SageTv and it worked fine using the MCE remote.. without focus.
PS when you Installed the MCE remote plugin for EventGhost did you also install the service? when you configured the plugin? The service name is AlternateMceIrService ... also make sure you are using the latest release of eventghost.
Old 11-16-2012, 02:42 PM
I'm running the client plugin and I installed the service. The remote works fine so long as I select something with the keyboard or mouse first within Sage. This only happens after a reboot of the client pc.
Old 11-16-2012, 02:43 PM
See My screenshot above that is all I have Installed... Also make sure the service is started and using an administrator login. Also if using Eventghost make sure in sage detail setup commands for remote configuration you have selected none external setup.
Old 11-16-2012, 02:46 PM
My setup is the same. And everything is running with administrator login.
BTW. Thanks for your time and patience with me on this.
Old 11-16-2012, 02:49 PM
Did you check this.
Old 11-16-2012, 02:50 PM
Did you check this.
I just checked before my last reply. Sage setup has external setup selected.
Old 11-16-2012, 02:59 PM
Sorry do not have anything else. I am using that same setup and even now while typing I can pause Sage in the background... turn volume up and down etc...
Old 11-16-2012, 03:35 PM
Thanks for your time on this. If I can't get it to work, its not a big deal to select something with the mouse/keyboard and then the remote works.
Old 11-19-2012, 10:30 AM
LOL.
Before I tried any of the changes suggested above (either add an action to bring SageTV to the front or a batch file to load SageTV last) I decided to update everything in Sage regarding the plugins and Gemstones.
All of a sudden, the remote works everytime the computer gets rebooted. Go figure.
Thanks to everyone that chimed in trying to help. It was greatly appreciated.
SlingBox Remote Setup: Closest Thing To HD200's Remote? PeteCress Hardware Support 1 07-08-2010 08:45 PM
Hauppauge remote conflict with Panasonic remote Sunderj Hardware Support 1 05-13-2009 08:59 AM
HD100 remote command problem on learning remote dfitz43 Hardware Support 1 03-22-2008 11:39 AM
Hauppauge 45 button remote issue (MCE kit remote) jlowery7 Hardware Support 12 04-16-2006 11:45 AM
Hauppauge silver remote and learner remote Crowdx42 Hardware Support 1 03-05-2004 05:49 PM
