Old 01-23-2021, 10:00 PM
Tokendude Tokendude is offline
Recording drives question
I've been running v1 of WHS for many, many years and have finally been forced to upgrade the OS. I've gone to Win10x64 for better or worse. The reason I used WHS was because of the "pooled drive" capability of WHS. I just added more drives as I needed them and let WHS handle drive/file balancing. My questions now are:
1) how does SageTV allocate files when more than 1 drive/directory is provided to SageTV for recording?
2) Is there any advantage (other than redundancy) to using "Storage Spaces" instead of listing multiple drives (I have 5 x 2TB) some of which will be for DVD storage and some for OTA recordings.
It's been so long since I've done much with SageTV other than just use it so I'm looking for a little guidance here. I tried searching the forum but could find much info for either question.
TD
Server: whs-Antec Three Hundred Case w/ extra HD cooling fans, Gigabyte GA-EP43-EU3L, Q9400processor (2.66Hz quad core), 4gig ram. Sage for whs 6.6.2, 3x1TB + 1x1.5TB + 1x2TB pool.
Capture: 2 HDHR's.
Clients: 3 HD200's.
Old 01-23-2021, 10:24 PM
If you configure multiple recording drives, SageTV will record to the one with the most available space.
So if you have 1 drive that has 500GB free, and another that has 100GB free, SageTV will always record to the 500GB drive until it drops below 100GB free.
There are also "Diskspace Usage Rules" when setting up your recording folders. You can use this setting to set a maximum amount of space to use per drive. You may be able to balance the storage SageTV uses across drives by tweaking this setting.
I can't help with the second question though.
Old 01-24-2021, 11:25 AM
I'll throw in an unsolicited plug for Unraid here. If you want to run an array, do drive pooling and let something else handle it, check out Unraid. I've got a 14TB array with parity, and it worries about which drive to write to. Sage just sees a recording share and it uses that.
I'm not sure what your watching habits are like, but around here, we tend to watch and delete. The few things we want to keep, I'll re-encode and move to a videos folder. Why not just dedicated one of your 2 TB drives to be a recording drive and use the other drives for other content?
Old 01-24-2021, 07:59 PM
Denali Denali is offline
In Detailed Setup : General there's also
Video Recording Path Optimization Style - Space/Bandwidth
HTPC: Gigabyte GA-Z170XP-SLI, I7-6700, 16GB, Windows 10 Pro x64, Hauppauge HVR-1600, WinTV-dualHD, Colossus 2, Samsung 850 EVO 120GB, Seagate 3TB, WD 3TB, 3TB, 5TB, Java v1.8.0_231, SageTVx64 v9.2.1.826, Samsung UN60EH6003F, Dish ViP222K, ViewHD 1x2 HDMI Splitter.
Old 01-24-2021, 09:49 PM
I also went from WHS to unRAID. The only downside is that it doesn't do client backups.
But I think Win 10 has something called Storage Spaces which is a successor technlogy to WHS pooled drives.
https://www.onmsft.com/how-to/how-to...-in-windows-10
Looking for recommendations on recording folders/drives Zogg SageTV Github Development 2 09-11-2016 10:16 PM
question about hard drives reboot_this The SageTV Community 3 02-02-2007 11:18 AM
Force recording to multiple drives NEOSG SageTV Software 14 01-21-2007 12:28 PM
1 out of 4 recording drives being ignored? geogecko SageTV Software 5 11-24-2006 03:42 PM
95+% fragmentation on recording drives evilpenguin SageTV Software 38 04-04-2006 06:30 PM
