Is my Tuner dying?
I've recently discovered that my Hauppauge 885 is only showing a signal for NBC and ABC. Nothing else is coming in. It is using the same channel map as my 7164 which appears to be working fine. I have an active amp/splitter between the antenna and the cards. Could it partially fail and cause this kind of issue?
Server: MS Win7 SP1; FX8350 (H2O cooled); 8GB RAM; Hauppauge HVR-7164 (OTA); HVR-885 (OTA); SageTV 9.1.5.x; 12+TB Sage Storage Clients: HD300 x2; HD200 x2; Placeshifter Service: EPB Fiber (1Gb); OTA (we "cut the cord"); Netflix, Hulu, etc. |
It's very unusual for the tuner to go bad with the symptom described. More likely this is a result of the channel repack that occurred. Try performing a channel scan on each tuner having this problem.
System #1: Win7-64, I7-920, 8 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HDHR-US (1st gen white) tuners. HD-200. System #2: Win7-64, I7-920, 8 GB mem, 4TB HD. Java 1.8.0_131. Sage v9.1.6.747. ClearQAM: 2x HDHR3-US tuners. HD-200. System #3: Win7-64, I7-920, 12 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HVR2250; Spectrum Cable via HDPVR & USB-UIRT. 3x HD-200. |
I'd check the amp/splitter. They sometimes fail - sometimes mine have gotten unplugged unintentionally!
Server: Windows 8.1 4gb RAM; 4TB SATA + others. Homebrew quad core AMD. Inputs: Haup. 980, 850 & 950Q on ATSC; Haup 1600 on ATSC & Comcast 2 DTAs with USBUIRT for NTSC. Haup 1800 on ATSC. HDHR Dual (ATSC). Sage 9.22 64 bit. |
Are you sure that there wasn't a frequency reshuffling in your area. Maybe you have to rescan for that other tuner.
https://www.oaoa.com/uncategorized/y...e-frequencies/
hvr1600 seems to be dying, best dual analog tuner replacement? | sam99 | Hardware Support | 0 | 10-16-2013 01:26 PM |
HDHR Dying - Is HDHR Prime any differnt for OTA other then 3rd tuner | personalt | Hardware Support | 2 | 11-19-2012 03:50 PM |
Is this community dying already? | wayner | General Discussion | 146 | 07-14-2012 10:57 PM |
USB-UIRT keeps dying | ericscottf | Hardware Support | 4 | 01-05-2011 07:13 PM |
Is my PVR-150 dying? | gilded07 | Hardware Support | 6 | 04-30-2008 03:12 PM |
