Can I add an extra line on the Program Guide screen?
I usually check ESPN and ESPN2 every day to see what sports are on that night. Unfortunately on my local program guide, ESPN is the last thing listed on one page, and ESPN2 is the first on the second. I'd like to add one more line to my program guide so I dont have to jump back and forth to check each channel. It's a minor headache, but something I'd like to change if possible. I feel pretty certain that I can do this, but I really don't know where to look in the setup menu or studio development kit. Thanks in advance for any help anyone can give!
Use the Options command while viewing the Program Guide; p. 44 in the v4 PDF manual in your SageTV dir.
Wow that was a fast response. Thanks Opus4!
You can change this by editing the sage properties file. I do not have access to my sage machine, so I cannot tell you exactly which lines to edit, but if you have edited the prop. files before you should be able to spot it. No need for studio for this.
HTH. Jesse EDIT: Opus strike first with something I did not know. Is this new in the options for V4? |
![]() - Andy
