I have tried now two versions of SageTV beta and the most recent official release and I can't get my Technotrend S-2 3200 to scan any satellites.
I try a satellite in DVB Dream and I make sure I have a good solid signal but it does not find anything at all in SageTV. I added transponder, symbol rate, FEC and polarity info into the predefinedDVBS.frq file for the sats I wanted to use. I have seen posts where some people say they got a pop up box asking for Local osscilator settings but I never get that. I have seen post where someone said they had a DVBs card.lnb file after adding the DVBs tuner card. I get nothing like that, I tried making my own .lnb file but I don't know how the card should be named. My card shows up in the tuner list as "TechnoTrend BDA/DVB Capture" I tried naming the file Technotrend BDADVB Capture-0.lnb and many other variations. I put this info in the .lnb file #LNB setup for TechnoTrend BDA/DVb Capture sat_no:0 sat_name:"G-10R (123.0 W)" LNB=10750-10750-0 I found some info for someones Hauppauge card and their .lnb file was named Hauppauge%20WinTV%2088x%20TS%20Capture-0[1].lnb I am lost on what else I can do here, it should not be this hard to set up a DVB card in a pvr program. In Media portal it is trivial to set one up. Thanks, Wayne |
Hi Wayne
Try the attached file - I have a slightly different model but hopefully it will work. Edit: file didn't upload so.. file name should be TechnoTrend-BDA-DVB-Capture-0.lnb #LNB setup for TechnoTrend BDA/DVB Capture sat_no:0 sat_name:"G-10R (123.0 W)" LNB=10750-10750-0 pos:None opt:None You will need to stop sage completely (including the service, before copying it in into your sagetv directory) Anne
ZZMystique ![]() My setup: Server: SageTV v7, Intel i5, 8GB, 180GB SSD, 4TB HDD, Win7HP & (DVB Viewer Pro with DVB Viewer for SageTV using 2xTBS6281 DVB-T2). Last edited by zzmystique; 06-28-2008 at 12:16 AM. Reason: file didn't upload |
Oh well it was worth a try - the only other thing I can think of is edit the file with
LNB=10750-10750-10750 pos:None opt:None or LNB=10750-10750-10750 pos:A opt:A or LNB=10750-10750-10750 pos:B opt:B etc And then reboot. (I had to reboot to get mine to work) Anne
ZZMystique ![]() My setup: Server: SageTV v7, Intel i5, 8GB, 180GB SSD, 4TB HDD, Win7HP & (DVB Viewer Pro with DVB Viewer for SageTV using 2xTBS6281 DVB-T2). |
I'm having a similar problem with my new TT s2-3600 device.. It works a treat in MyTheatre, ProgDVB, etc But won't scan anything through the latest beta no matter what I've tried so far...
Cheers Peter |
with latest beta 6.4.4 you should not have to write a .lnb file manually, you can enter the needed info via the sage setup (add sat provider), if you don't have this dialog, start out with a fresh install
...i have a running s2-3200 with diseqc switching enabled, and i did not have to manually edit the .lnb file (just entered LOF1, LOF2, LOF SW and diseqc pos/opt)
WWW: http://www.krikkit.net Server: Athlon X2 4850e (2x2,5Ghz); AMD 780G Chipset, 2 Gb RAM ; ATI Radeon HD 3200; Technotrend S2-3200 DVB-S + CI, Hauppauge PVR 150 (only as IR receiver) Winows XP Pro; SageTV v6.4.5 Clients: Placeshifter |
[SIZE="1"]Peter L. Sage Server - Dual Intel i7, 16 GB RAM, 4 TB RAID 0 Disk, 5 x HD-PVR (BellTV HD), 5 x USB-UIRT, Windows 7 64-Bit on VMWare ESXI 5.1, SageTV 9.x Open Source Clients #1 to #3 - HD300 Client #4 - Shield Android TV running Mini Client Client #5 - Sony Bravia Android TV running Mini Client |
STV Update Tests for beta v6.4 | Opus4 | SageTV Beta Test Software | 64 | 07-23-2008 11:06 PM |
SageTV V6.3.2 Beta is Available! | Narflex | SageTV Beta Test Software | 0 | 11-21-2007 07:08 PM |
Umm - Why is Sage 6.1.8 looking for the wiz file in the beta dir? | tawpgk | SageTV Software | 3 | 04-24-2007 12:27 AM |
Why are we in beta hell here? | Bohica | General Discussion | 76 | 02-19-2006 10:43 AM |
