Old 04-11-2017, 08:25 PM
Windows 10 Creators Update MPEG2 Decoder
If you update to the Creators build you can download free from the windows store the ..
"MPEG2 Video Extension"
It is free.
You can update early if not available in your area here.
https://www.microsoft.com/en-us/soft...load/windows10
Old 04-12-2017, 07:07 AM
So if it is a free download then wtf don't they include it as part of the core OS upgrade?
Old 04-12-2017, 07:43 AM
dstanley's Avatar
dstanley dstanley is offline
I would assume that since royalites have to be paid on every MPEG2 decoder that MS can get away with only paying for downloads for people that really want it - or even know about it!
Otherwise they would have to pay for every OS upgrade out there ...
Just my guess ...
Old 04-12-2017, 08:00 AM
Just my guess ...
That sounds reasonable......
I posted it because anyone that has a Prime can by downloading the decoder and the HDHomerun View APP from the app store can watch DRM on Windows 10 PC's... for free.
Old 04-12-2017, 09:34 AM
Copy freely, copy once and copy never?
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.8.3, SageTV & OpenDCT Dockers
Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K w/MiniClient
Old 04-12-2017, 10:48 AM
Anything that is protected and can only be viewed with a cable box or WMC. Without additional hardware like a HDPVR...etc
Old 04-17-2017, 11:20 AM
I tried this out this past weekend using a Microsoft Wireless Display Adapter connected to my main TV. I gotta say it was pretty cool watching premium (copy-once) content from my HDHomeRun Prime without needing a cable box. In fact, I should be able to ditch my $10/month cable box now...
Old 04-17-2017, 06:56 PM
Yeah I ditched 2 boxes with PC Sticks.
Old 04-19-2017, 09:33 AM
Sounds cool - the adapters are about $50, correct? How do you control the UI? Do you use an RF remote control?
Old 04-19-2017, 10:00 AM
What I did this past weekend was more of a proof of concept; the TV that I was using is probably about 10 feet away from my desktop computer, so the screen sharing was done from my desktop, using the wireless keyboard and mouse that is connected to my desktop. Going forward, I would probably use a laptop computer with it's own keyboard/mouse to share the screen.
If you didn't want to bother with the screen sharing, using the ASUS PC stick that nyplayer referred to might work out well. You would need to figure out what kind of controller you want to use (keyboard, mouse, etc.).
Old 08-20-2017, 05:16 PM
KryptoNyte's Avatar
After installing this;
https://www.microsoft.com/en-us/stor...n/9n95q1zzpmh4
on a Windows 10 SageTV V9 client, what selection do you make in the Sage UI in the list of video decoders for mpeg2? There was only one listed, but didn't work, so I listed them all, and can't seem to get any of them to work either.
Old 08-21-2017, 05:48 PM
KryptoNyte's Avatar
Am I missing something in the mpeg2 decoder from the above post - do I just need to download the LAV filters and be done with it? I have numerous client licenses, is there just something I can grab from the V9 server (that was upgraded from V7)?
Old 08-21-2017, 05:52 PM
KryptoNyte's Avatar
Wait - is there a way I can install my original SageTV V7 client, and then install V9 client effectively getting an mpeg2 decoder active?
Old 08-21-2017, 08:07 PM
jusjoken jusjoken is offline
Yes. If you install 7 and then install v9 in the same folder it will retain the sagetv decoder
k
Old 08-22-2017, 06:15 PM
KryptoNyte's Avatar
Thanks, JJ. I'll install V7 and then V9 over top to same dir and see how it goes.
Old 08-23-2017, 11:12 AM
thomaszoo thomaszoo is offline
Any idea if this can be used with the Ceton InfiniTV?
i5-6400, MSI B150M Micro ATX MB, 16GB DDR3 1600, 2 - WD Green 2TB SATA Drives, Lite-On SATA 4X Blu-ray Reader, Corsair 400W 80+ Power Supply, Silverstone Sugo SG02-BF MicroATX Case, Windows 10 (64), HDHR Dual X2, Quatro and Prime, 5 x HD300 + 2 x HD100
Old 08-23-2017, 06:15 PM
KryptoNyte's Avatar
That can't be used with the Ceton. That company never took their development to that level.
MPEG2 Decoder frustrations Oats SageTV Software 15 04-30-2010 01:42 PM
MPEG2 Decoder Question badger02 Hardware Support 1 01-08-2010 08:12 PM
ATI MPEG2 decoder sgtchoice SageTV Software 1 05-14-2009 08:48 AM
Whats the best mpeg2 software video decoder for mpeg2 1080i? mkanet SageTV Software 7 12-19-2008 05:14 PM
mpeg2 decoder error mangriotis SageTV Software 9 03-30-2003 04:01 PM
