New FTA channel is mpeg4
We just got a new FTA channel here in Australia (7food) - but after adding it to my lineup in SageTV, I get the following error while trying to preview it on my server:
There was a Playback Error in playback. Details: sage.PlaybackException: ERROR (-5,0x80040200): There was a problem rendering the audio portion of the content for playback.Now I did some Googling and noted some comments online that the new channel is broadcast in mpeg4 and that some people with older TVs won't be able to play it. So I'm guessing I'm hitting some kind of Codec issue? Is there something I can change in the settings or install to allow SageTV to play/record this new channel? |
Rather than just previewing, you should make a short recording from the channel. Then see if you can play it back with another program. Assuming it is playable, you can use something like mediainfo to figure out what audio and video codecs were used. With that information, someone here might be able to tell you how to get Sage to play it.
Good point - here is what Mediainfo reported about the created file.
General Complete name : C:\Data\Recorded TV\TV1\TheKitchen-Season15Episode02FeastOfFullFlavour-10238339-0.mpg Format : MPEG-PS File size : 31.2 MiB Duration : 2 min 32 s Overall bit rate mode : Variable Overall bit rate : 1 717 kb/s Video ID : 224 (0xE0) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 4 frames Duration : 2 min 31 s Width : 640 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Scan type, store method : Interleaved fields Scan order : Top Field First Audio ID : 192 (0xC0) Format : AAC LC SBR PS Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication and Parametric Stereo Commercial name : HE-AACv2 Format settings : NBC Muxing mode : LATM Codec ID : 2 Duration : 2 min 32 s Bit rate mode : Variable Channel(s) : 2 channels Channel layout : C Sampling rate : 48.0 kHz Frame rate : 23.438 FPS (2048 SPF) Compression mode : Lossy Delay relative to video : -2 s 96 ms |
Actually - crisis averted ... I just tried watching the new channel via the HD200 and it worked fine - that thing can do almost anything!
I don't watch via my server (I was only testing new channel lineups there), so doesn't matter if can't view stuff there. |
We ran into that problem quite some time ago. The link to the decoder codec seems to be long gone, but here's a copy that I use on my server.
And some instructions on how to register it. John |
Converting to mpeg4 | antplugger | General Discussion | 10 | 04-18-2006 05:57 AM |
MPEG4 | itons | Hardware Support | 2 | 02-06-2006 08:25 AM |
MPEG4 | itons | General Discussion | 4 | 12-12-2005 12:54 PM |
DirecTV and Mpeg4 | Ralphjb | General Discussion | 9 | 01-10-2005 11:56 AM |
