Old 10-10-2010, 02:12 AM
perfessor101 perfessor101 is offline
Driver problem: HVR-2250 and 7.8.28.28064 : anyone else?
Hello,
I just tried the latest HVR-2250 drivers from Hauppauge (7.8.28.28064)
The drivers seem to be changing the video resolutions in my recordings at random up to four times an hour.
If I just watch the file there isn't much of a problem.
If I try to cut commercials with videoredo it stops and complains.
I asked in the VideoRedo support forums what to do and they said that Quick Stream Fix has an option for 'enable filters' and then you can select '720x480', but this only works some of the time and I loose up to one fifth of the recording (if it were only the commercials ...)
So I am posting this to find out if anyone else with multiple HVR-2250's is having a problem with this driver set ... or as a warning to those who have not tried it yet and are cutting commercials with videoredo.
If anyone has any solutions to get this driver set working?
or they have a setup with multiple HVR-2250's and a known well working driver set?
(27323 will not allow me to select recording rate with more than one HVR-2250)
Thanks for your time,
Bobby
SageTV Server: Windows 7 64Bit, Phenom II X6 1090T, Asus M4A89GTD-PRO/USB3 (AM3), ATI Radeon HD 4290, 2 x KHX1600C9D3/4GX, 4 x HD-PVR2 Gaming, , 4 x 320GB recording drives, 2 x USB-UIRT, SageTV Server Beta
SageTV Client & 2 x HD-300 Extender.
40.8TB unRaid 6.6.5 media server
7.8.28.28064, hvr-2250
New HVR-2250 Driver 28162 rrhorer Hardware Support 1 06-23-2010 08:43 AM
HVR-2250 driver fix for recording 2 analog channels at the same time Opus4 Hardware Support 40 11-19-2009 05:08 PM
Updated HVR-2250 Driver mbowling Hardware Support 2 05-02-2009 09:21 PM
Hauppauge HVR-2250 MC Kit Problem Rafiki2085 Hardware Support 0 11-08-2008 12:33 PM
