Old 08-06-2016, 07:22 PM
RRRitchey RRRitchey is offline
HVR-2250 OTA Tuning Problems
I am trying to test going from cable to OTA this weekend. I have two computers, each has a WinTV-HVR-2250 that I have been using for about 9 years now without a problem on cable. I removed all the sources and then rebooted just for good measure. I added each source back in using the DTV tuner setting and the local digital broadcast program source. I then rebooted again before doing a channel scan. When I did the scan it found no channels. I have the cable split into my TV so I did a scan on it and it found 82 channels and I could watch them. I cannot figure out why the HVR-2250 is not finding any channels. When I try to preview it tells me there is an error with the capture device but it was working fine this morning on cable. Also, when I look at the tuner settings it say the broadcast setting is QAM NET. I guess I thought I would see ATSC. Also, when it scans the channels it only goes up to 69 but one of my channels is logical 3-1 but physically 74-3-1. I am running Sage V7 right now on Windows 7 Professional. I did not want to change too many things at once unless I am better off going to the new Sage version. I am lost, anyone have some ideas for me? Thank you very much.
Old 08-06-2016, 07:55 PM
JustFred JustFred is offline
Yes, Sage should report ATSC (not QAM; that's the cable standard). It's reasonable to see logical 3-1 associated with physical 74-3-1.
Have you tried doing a channel scan using Hauppauge's WinTv app? That'll remove Sage from the equation. (It's ok to have Sage & WinTv installed at the same time). Could be something as simple as connecting the coax to the wrong F-connector on the tuner? ATSC and QAM use the same input connector; the 2nd F-connector is for the FM tuner.
Sage 7 and the HVR2250 with OTA ordinarily "just works" on Win7 without jumping thru any hoops. I have 2 such systems that have run without issue for over 5 years.
Old 08-07-2016, 10:07 AM
Well, I have no idea what is going on but when I scan the channels it tells me it can find no tunable channels. But when I actually go to the channels I can get them. Also had issues with the program guide. When on cable I set it up so that the digital tuner channel list was the local digital broadcast program. When I tried to reset up for OTA it asked if I wanted a new program guide and I said yes but I still got the old OTA channel list with all the odd ball places Cox stuffed other digital channels. I had to change my zipcode to get it to load a fresh copy for my area. Luckily there are lots of Phoenix zipcodes. So, at this point its working again but channel scanning does me no good. Thanks for you input.
hvr-2250, ota, scanning
HVR-2250 Problems? bigo93bronco Hardware Support 24 09-04-2011 01:36 PM
HVR-2250 no analog tuning jasongrimme SageTV Beta Test Software 17 01-20-2011 09:44 AM
v7.0.12 Problems with HVR 2250 and mkv's rrhorer SageTV Beta Test Software 21 07-23-2010 08:21 AM
HVR-2250 QAM Tuning Problem Solved rrhorer Hardware Support 1 06-14-2010 07:54 PM
Hauppauge 2250 digital tuning to KPNXDT in Phoenix area azsndvl Hardware Support 0 04-05-2009 08:44 AM
