Old 10-26-2014, 04:56 PM
tvmaster2's Avatar
dual core or quad core AMD processors
I have been using a dual-core AMD Athlon 2.9 processor for a few years.
It's fine for Sage playback thru media extenders.
However, lately I've started adding iPad apps, HBO Go Netflix, Playon into the equation, and I've noticed extreme jerkiness/sluggishness when you request to playback a HD stream on the iPad, in addition to whatever live TV is running thru Sage. Requesting a stream for a lower resolution device like an Android phone causes no problems.
Streaming from my home network on the iPad, directly to HBO Go, etc, in HD, causes no problems. Only when a HD app makes a request to the Sage server (Playon - Air Video HD)
Would a quad-core help to alleviate this problem, and is live transcoding the reason for the bottleneck?
4 gigs of ram in a W7 32bit box (need 1394 channel change, so that's it for ram). Video card is Gigabyte on-board HD4200 Radeon.
So, would a quad-core eliminate the sluggishness? What kind of frame rates does the server have to offer up for two, simultaneous HD streams: 200fps?
Old 10-26-2014, 07:09 PM
KryptoNyte's Avatar
What's the current processor usage when you experience the sluggishness?
Old 10-28-2014, 12:22 PM
SWKerr SWKerr is offline
If I recall Playon recommends a 4x CPU. I have an i5 4 core on my main server and I have noticed that if I am compressing a BluRay I get that kind of playback problem on both Plex and Playon. Plex seems a little better under load than Playon but they are essentially re-encoding video on the fly so cpu would be important.
So I would say it is likely you need a 4 Core. If you have Comskip or something cpu intensive running you might try disabling it to see how it works. Intensive I\O can use significant cpu so 2 cores really are not that much past the basics. There is a Systems test built into Playon that might tell you something as well.
Old 10-30-2014, 11:38 PM
tvmaster2's Avatar
100% for a couple of minutes, then it bounces back and forth between 85 - 100 %, when two HD streams are used
Old 10-30-2014, 11:44 PM
tvmaster2's Avatar
Thanks. It passed the system test, but I don't believe I had two streams active.
Air Video seems to be able to stream a HD file, but it transcodes to SD on the fly, which apparently isn't as taxing?
To get a faster dual-core or slower quad-core? That is the question... robogeek Hardware Support 33 03-09-2009 08:33 PM
ERROR (-10)... Only with Quad core, not Dual core? jerryt Hardware Support 2 04-03-2008 07:13 PM
quad core vs dual core garyellis Hardware Support 16 03-13-2008 10:36 PM
HD Homerun and DUAL CORE processors srothwell Hardware Support 12 04-28-2007 09:44 AM
Dual Core processors and Placeshifting ldavis SageTV Placeshifter 5 04-13-2007 05:16 AM
