Old 05-30-2003, 01:40 PM
grot grot is offline
Documentation & Logos?
Has anyone compiled:
A list of what all the various commands in the setup file do? Sorry, not at that PC, called profile or something? Some of them seam like they'd be useful, but I'm reluctant to just hack at it without knowing the format.
A set of TV channel logos?
Old 05-30-2003, 01:47 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Check out the "I love the new UI" thread for information on channel logos.
I just made a list of the properties about an hour ago, here it is. Anything accessible through the UI was left out on purpose. The quality settings in the properties files are not discussed here either. There's a whole document on that in the developer's section of our website.
Configurable properties for SageTV. The videoframe properties also apply to SageRecorder.
auto_categorize_epg - true/false
enable_picture_library - true/false
epg/epg_import_plugin - Java class name for EPG plugin
epg/scale_logos_to_ntsc_colors - true/false improves contrast of channel logos on a TV
screen_saver_wait_time - milliseconds till SageTV Screen Saver kicks in when enabled
seeker/channel_change_ask_advance - amount of time before SageTV needs to change the channel that it will ask, in milliseconds
seeker/delete_partials_on_exit - true/false deletes all of those little files when you quit SageTV
seeker/library_import_filename_extensions - list of filename extensions that are valid for Library importing
seeker/max_duration_encoder_reset - the maximum amount of time that can pass before resetting an MPEG encodere, in milliseconds
ui/default_epg_col_duration - millisecond width of the columns in the EPG
ui/default_epg_num_cols - num columns in the default EPG
ui/default_epg_num_rows - num rows in the default EPG
ui/dfont_adjust - amount to adjust the font sizes by in the UI
ui/dfont_name - font name to use in SageTV
ui/disable_screen_saver_and_pm - true/false, will turn off system screen saver and power management when SageTV is in use if true
ui/time_scroll_amount - milliseconds for each adjustment in time scrolling
ui/ui_overscan_correction_offset_x - amount to shift left/right the UI to account for overscan on a television display
ui/ui_overscan_correction_offset_y - amount to shift up/down the UI to account for overscan on a television display
ui/ui_overscan_correction_perct_height - amount to shrink/expand the UI's height to account for overscan on a television display
ui/ui_overscan_correction_perct_width - amount to shrink/expand the UI's width to account for overscan on a television display
videoframe/additional_audio_filters - additional options for the Audio Decoder Filters. Semicolons separate groups, comma separate elements within groups. Groups are FilterName,FilterInputPin,FilterOutputPin
videoframe/additional_video_filters - additional options for the Video Decoder Filters. Semicolons separate groups, comma separate elements within groups. Groups are FilterName,FilterInputPin,FilterOutputPin
videoframe/ff_time - milliseconds adjustment for FF
videoframe/ff_time2 - milliseconds adjustment for FF2
videoframe/rew_time - milliseconds adjustment for REW (should be negative)
videoframe/rew_time2 - milliseconds adjustment for REW2 (should be negative)
Jeffrey Kardatzke
Google
Founder of SageTV
Old 06-03-2003, 06:15 PM
laurenglenn's Avatar
laurenglenn laurenglenn is offline
Send a message via AIM to laurenglenn Send a message via MSN to laurenglenn
Re: Documentation & Logos?
There's a site here ( http://www.satlogo.com/tvcountry/us1.html ) with logos for all channels (as far as I know) in the US. Some of the files are .JPEG files and need to be renamed with the channel name with a ".JPG" in order to work if they are JPEG files.
Lauren
