Old 06-16-2008, 07:03 AM
Beaker's Avatar
Beaker Beaker is offline
24-Hour Weather Update Only
I'm having a problem with the weather component of my Sage 6. Here's the deal. I'll open the click on Weather and it will open with fresh data, always less than an hour old. Later in the day, say 3 hours, I'll open it again, but it won't update. If I wait a full 24 hours from the first update, it will update with fresh data again. Otherwise, if I change the zip code info, it will update instantly.
This wasn't didn't always do this. I think it was working properly about 3 weeks ago. Perhaps there's a conflict with some of the recent Windows Updates?
Can you help? Here's what I think might be helpful:
WinXP Home
Windows Firewall
No problems with EPG
weather_cache.properties has been deleted and auto-recreated
Thanks for whatever you can do!
"Worry does not empty tomorrow of its sorrow; it empties today of its strength." Corrie Ten Boom
Core-i5 6600k
16GB RAM
Hauppauge WinTV-QuadHD
Win10
Old 06-16-2008, 09:19 AM
The weather source (weather.com) changed its service. Use the v6.4 beta for updated weather support.
Old 06-16-2008, 10:40 AM
Beaker's Avatar
I'm not sure I want to run Beta software. Is it stable? Is there some way to incorporate the updated weather portions without moving to v6.4 beta?
Core-i5 6600k
16GB RAM
Win10
Old 06-16-2008, 11:18 AM
It has been stable for me. If there are problems with the software, the beta period is a good tiome to find them & let SageTV know so the issues can be fixed instead released that way.
No, some of the weather changes are in the core and that is only updated in v6.4.
Old 06-16-2008, 12:32 PM
Beaker's Avatar
Very well then. Thanks much. Maybe I'll try the beta.
Core-i5 6600k
16GB RAM
Win10
Old 06-16-2008, 01:05 PM
CollinR CollinR is offline
Sage's betas are not like most the betas seem to be very well tested internally and is a buffer so many web users can test it before it's the production download on the main site.
Old 06-16-2008, 04:23 PM
Tiki's Avatar
Tiki Tiki is offline
Of course if you are really worried about using a Beta, you can always just live with the reduced functionality for Weather that you have for now and wait until the next formal release.
Sage will never comment on when the next beta or full release will be out so you won't know if it will be days, weeks, or months that you have to wait. Historically, it seems like they put out a new Beta, Release Candidate, or full release about every 3-12 weeks. The last Beta was put out a couple of days ago.
If you are thinking of trying a Beta, I suggest looking at the Beta section of this forum to see what kind of success or problems other people are reporting. Also, do the install on a day when you have a few hours free and nothing critical that you need to record, just in case you run into problems, and make a backup of your Sage folder before you start. Chances are, it will work fine for you, but you never know...
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
EPG Update schedule all over the place Franc SageTV EPG Service 3 05-19-2007 07:39 PM
STV Import: Weather Monitor deria SageTV Customizations 35 08-23-2006 08:15 PM
Schedule of the EPG update Franc SageTV Software 3 08-16-2006 12:00 PM
Definitive answer on EPG Update times Franc SageTV EPG Service 2 07-05-2006 12:20 PM
