Old 12-29-2012, 11:45 AM
craigap craigap is offline
Warning Message about EPG data
According to this thread http://forums.sagetv.com/forums/showthread.php?t=59664 on the 18th of December, EPG data will continue for now. However I received a Warning message about my EPG data today and was wondering if anyone could tell me what it means and if I can do something to fix it. Please refer to the attached screen shot for details.
Windows 10
Sagetv 9 64bit (9.2.5)
HVR-2255 x3 OTA
Old 12-29-2012, 01:17 PM
asd asd is offline
Different country, different cable provider, same message
I got the same message today. I've never seen it before, either.
Old 12-29-2012, 01:38 PM
Got it myself today on one of my OTA lineups. Figure all the OTA lineups I have setup (one for each tuner on each of 4 servers) will be dropping when they next update. I turned in a service request for this just now so it should be fixed before the EPG runs out.
Old 12-29-2012, 01:43 PM
panteragstk's Avatar
Yep, got one for directv. Not cool.
Old 12-29-2012, 03:13 PM
Ericft Ericft is offline
no more channel lineup
I got one as well here in comcast chester coatesville...what do i need to to?? panicking...
SageTV Server: Windows 7, Intel Core i5-760 2.8GHz, 7.19 Final, 500Gb System, 2TB + 640Gb recording drive
Rosewill RS-x 4 Esata RAID 5 enclosure 4x1.5tb HDD backup
UNRAID Server Pro: storing dvd and blu-ray rips, music
Extenders: HD300 x2
Tuners: HD Homerun Prime, HD Homerun, HD-PVR, Comcast Cable Box DCH-6200
Old 12-29-2012, 03:19 PM
Rob Rob is offline
Me too.
I don't think Jeff would say it will continue unless he means it. But I am still a bit worried.
Old 12-29-2012, 04:18 PM
jorton jorton is offline
This has happened before and it self corrected... seems that Zap2It may be up to something on their end as they provide the data...
Read here if you want to see us similarly freaking out, then it self fixing and life going back to normal
http://forums.sagetv.com/forums/show...97&postcount=1
Old 12-29-2012, 04:43 PM
Brent Brent is offline
fwiw: I have that message as well TWC in KC.
Old 12-29-2012, 04:48 PM
I figure zap2it's just being dumb. We should be fine.
Old 12-29-2012, 06:26 PM
graywolf's Avatar
graywolf graywolf is offline
Not sure it's necessarily at zap2it's end.
When I go to zap2it, I'm able to select my lineup on their website without issue.
But I did get the Error today at EPG update time and checked zap2it's site right afterwards
DirecTV - Charlotte
Old 12-29-2012, 06:58 PM
KryptoNyte's Avatar
KryptoNyte KryptoNyte is online now
Have not received any errors.
TWC Milwaukee.
Old 12-29-2012, 08:01 PM
As previously seen back in July/August, in the above linked thread, the Zap2it lineups were still there if you checked online but there was an issue with the lineups temporarily being removed/unavailable from the EPG data used by Sagetv. It also wasn't for all areas and they all eventually came back.
Old 12-29-2012, 08:07 PM
macsupergeek macsupergeek is offline
No error here and I have EPG data out to Jan 9.
FIOS - NJ
SERVER: Dual Core Xeon 3.0GHz 5160, 8gb RAM, Win7 x64, SageTV 9.0.13.536 w/ BMT, WebUI, OpenDCT, Java 1.70_79
TUNERS: 2 x Ceton PCIe InfinitiTV - FIOS
STORAGE: UNRAID - 8tb for archived shows, DVDs, pictures and music
CLIENTS: 2 x HD200s, 2 x HD300
Old 12-29-2012, 09:42 PM
pjpjpjpj pjpjpjpj is offline
Got it for one of my two OTA tuner locations, sure I'll get it for the other soon. I'm actually not worried - this same thing happened before (as mentioned above) and it ended up being no big deal. Jeff said EPG would continue, I trust his word.
I'd actually be worried if no one else had seen it because I'd think my system is broken. As soon as I saw this thread here, I was relieved.
Old 12-29-2012, 10:26 PM
orangerguy orangerguy is offline
Channel lineup Lost from EPG Server
Just got the infamous lineup lost warning about 90 minutes ago. Guide data runs through 1/10 @ 5pm. My lineup is Cox Communications Digital - Tulsa. Everyone else seeing this also or is this an anomoly? Need to reasearch how to back up this source before I try deleting and readding it. I have the mc2xml EPG plugin but have never had the chance to test the lite or pay versions yet.
Old 12-29-2012, 10:44 PM
CptKirk CptKirk is offline
Just got it as well at 8:47PM CST 12/29/12.
'The lineup "Comcast Digital - Houston" no longer exists on the EPG server. Updates to this lineup will no longer occur.
SageTV running on: Win7 SP1 64 Pro
SageTV 9.2.5.936 (32 bit)
Java 1.8.0 301 (32 bit)
OpenDCT 0.5.32 (32 bit) (Comcast Music channels set to FFmpeg)
Clients: HD300 (x2)
HDHR3-CC Prime 20190621 (Comcast CableCard) - 3 Tuners
Hauppauge 1950 STB SD (USB-UIRT Zone 1)
Hauppauge 1950 STB SD (USB-UIRT Zone 2)
Old 12-30-2012, 12:34 AM
bigbill's Avatar
bigbill bigbill is offline
Yikes, I got it too... Warning - Channel Lineup Lost from EPG Server... The lineup "Digital Broadcast -"9212x" no longer exists on the EPG server. Updates to this lineup will no longer occur.
Home DVR: SageTV v9.2.2(64)
Dell T-40, xenon, 24GB RAM, Win10 Pro, 2 x 6TB WD Blue, QNAP TR004. 1 Quad HDHR, 2 Dual HDHR, (OTA Winegard HD8200U, CM4221HD), 2 @ STP-HD200's, 1 @ HD300, 1 @ Nvidia Shield 2017, 70", 55" & 40" Sony's - Playon/PlayLater, Blue Iris.
RV DVR: SageTV v9.2.2, NUC8i5BEK 16GB, SS980Pro NVMe, Nvidia Shield 2017, Mibox, 1 Dual HDHR 5TB Passport, Winegard BatWing, 40", 32", 28" Sony's, BlueIrisv5, Max Transit
Old 12-30-2012, 07:04 AM
gary201 gary201 is offline
Confirmed as well "Time Warner Cable - Rochester" NY was also lost. I'm guessing it's just a temporary glitch like has happened many times previously.
Old 12-30-2012, 08:45 AM
Yep. Same here.
Old 12-30-2012, 09:28 AM
drewg drewg is offline
And here. "Digital Broadcast 23116" for me..
Drew
Server HW: AMD Ryzen Threadripper 2990WX 32-Core
Server SW: FreeBSD-current, ZFS, linux-oracle-jdk1.8.0, sagetv-server_9.2.2_amd64
Tuner HW: HDHR
Client: Nvidia Shield (HD300, HD100 in storage)
Warning - Capture Device Failure while Starting Data Scanning SDeGonge Hardware Support 1 01-09-2011 06:05 AM
SageMC "OK" message on main menu. Error message? 49studebaker SageMC Custom Interface 7 01-31-2009 09:50 AM
Warning: ApplicationStartedHook and Placeshifter nielm SageTV Studio 4 09-24-2007 09:26 AM
Sony SAT B3 Warning! JUC Hardware Support 5 04-06-2005 07:50 AM
