Old 12-09-2019, 08:15 AM
PeteCress's Avatar
Setup | Set Up Video Sources | Preview Works OK, but TV | Program Guide Does not?
I can preview channel 3.1 in Setup | Set Up Video Sources , no problem.
But Sage throws "No Signal" when I try to tune it in Program Guide.
Also, the show's title in Program Guide (some sort of sitcom series) is obviously out of synch with the actual content being broadcast (a news show).
Seems like I must have my tuner set up OK and it seems like at least part of SageTV is ok....
Can anybody point me to a possible problem area?
Server: SageTV 7, Windows 7, Intel i7 @3.5GHz, 8 GB RAM, 80-gig SSD drive
Clients: HD200*4 over Cat5e Ethernet + Asus Zen running Client over WiFi-ac + 1 HD200 remote at another residence
Storage: NetGear Ultra-6 NAS 10 TB total w/dual redundancy. Plus (3) 2-tb local drives for RecordedTV.
Program Source: OTA antenna
Old 12-09-2019, 08:23 AM
Tiki's Avatar
Tiki Tiki is offline
Are you sure Sage is using the same tuner in both cases? During setup you can select a specific tuner, but from the program guide Sage chooses (seemingly at random).
Donít forget if you have a multi-tuner device that requires scanning for channels, you usually have to scan each tuner separately.
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 12-10-2019, 10:38 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
I had the same (similar?) situation. In Denver, when I used SageTV to scan for Channels, I found listed two Channels with the same numbers; 3-x and 10-x.
For instance: (applies to all sub-channels)
3-1 KSBSCD [19-3-1]
3-1 KCDODT [23-3-1]
10-1 KSBSCD [19-10-1]
10-1 KCDODT [23-10-1]
However, when I used HDHomeRun Setup to scan, only the 19-x-x was found. I, then, went back to SageTV Setup and found that the 23-x-x Channel was enabled and 19-x-x was disabled. When I switched that, everything worked as expected.
I believe this is actually an issue with Schedules Direct and not with SageTV.
Program Guide Listings with two sources? timg11 SageTV EPG Service 17 10-25-2017 08:39 PM
Video Source Setup - No providers listed - Program Guide = No Data calibrate SageTV EPG Service 14 10-21-2009 06:13 PM
Channel Setup Preview works - Watch TV does not MalibuDave42 Hardware Support 4 10-06-2009 04:29 AM
Program Guide and Multi-Sources TechBill SageTV Software 0 09-25-2007 04:11 AM
2 Vid Sources, Same program guide data, different channel lineup? rob.sfo SageTV Software 7 02-21-2007 08:36 PM
