Old 01-09-2012, 08:54 AM
AJ Bertelson AJ Bertelson is offline
do all versions of silicon dust tuners work witg digital ota?
The wide and I are going to drop cable in the next month or so. With two kids we just don't have the time anymore.
With that being said I still have one of the silicon dust dual tuners, but I annotated sure id it works for ota stuff now that everything is digital. I am going to grab an antenna and just plug it into the runner but if it doesn't work what will I need since its a coaxconnwction?
Old 01-09-2012, 10:59 AM
The Prime (cablecard) doesn't, but the rest do (unless you're talking one of the european DVB-T ones).
Old 01-10-2012, 10:42 AM
Thanks stagger, any recommendations on antennas?
Also we are close to being 10year members next year. Man remember those first releases.
Old 01-10-2012, 10:52 AM
pjpjpjpj pjpjpjpj is offline
Search these forums for "OTA". There are quite a few threads discussing OTA reception, antennas, installation, etc. The type of antenna that will work best for you is dependent on where you live, where the broadcast towers are located with respect to you, what's in between (hills? buildings? trees?), where you locate the antenna, house construction (if you put it indoors, such as an attic), etc.
Check out www.tvfool.com, put in your info, take a screenshot of your results and post. Lots of people will be willing to comment.
Old 01-17-2012, 10:38 AM
Do you have your attic designs posted anywhere?
Old 01-17-2012, 11:12 AM
At this point, I'm more interested in the next one...
Will one charter digital box and two tuners work?? Mtlca401 Hardware Support 3 07-07-2009 07:30 PM
Silicon Dust HomeRun: Mystery Channels? PeteCress Hardware Support 5 02-20-2009 09:43 AM
Silicon Dust HomeRun: "No Signal"? PeteCress Hardware Support 2 02-16-2009 06:47 PM
"No Signal": Silicon Dust HomeRun? PeteCress Hardware Support 8 02-12-2009 06:17 PM
Added BDA support for the HDHomeRun from Silicon Dust camus SageTV Beta Test Software 28 07-20-2007 11:24 AM
