Old 10-16-2012, 12:58 PM
BigMac BigMac is offline
SH id vs EP id Recording options
Is there a favorite option to not record shows with the SH id?
I have a situation and want to know if anyone else has solved this problem. My daughter is now old enough to watch and enjoy shows like Sponge Bob and old Three Stooges (only with me present to ensure parental guidance, that's what I tell my wife and I'm sticking to it). The problem is that the majority of these shows have the status of rerun but I only want to record shows that have the ShowID EP#### and NOT the SH### ID shows.
I had First&Rerun for SpongeBob just to capture as many episodes as I could but recently changed that to First Runs Only and then deleted (by hand) all those episodes with ShowID of SH3077660000 keeping only the EP IDs.
Just to keep the tuner conflicts down I've gone ahead and and "looked" ahead and marked future SpongeBob's with SH ids as watched. As time gets nearer to airtime they sometimes change the SH id to an EP id and SageTV records or doesn't depending on whether we already recorded it.
BTW: Been using SageTV since late 2002. My daughter is now 8 and looks incredulous at other kids in her class that can't watch their favorite cartoons at any time she (we) want.
Headless Server: SageTV V7.1.9.256, Homeseer3, HSTouch, Win 7 Pro (64Bit) Intel i3 3.30Ghz, 4G Ram, 8Tbyes,
2 HDHomeRun Primes/SageDCT 2.7.2 and 1 HDPVR (Total of 7 tuners), Intel 1Gb Nic
Client1: Win7 Pro (64bit), Q9450, 2G Ram, 700G of storage, MS DTV-DVD Decoder, ffdshow Video Decoder, Ac3Filter, EVR, LG HD DVD R/W, EN8600GT to HP 50" Plasma
Client2: Win7 Pro (64bit), Intel Quad Q9650 3.00GHz, 8G Ram, Test/Work/Gaming system.
Old 10-16-2012, 02:14 PM
Slugger Slugger is offline
Add a keyword to the favourite:
"EP\d+" (include the quotes)
That will prevent a fav from recording unknown (SH*) episodes.
Twitter: @ddb_db
Capture: 2 x Colossus
STB Controller: 1 x USB-UIRT
Old 10-17-2012, 06:50 AM
mundale2530 mundale2530 is offline
It works for me by adding the keyword EP* to the favorite.
Old 10-17-2012, 08:51 AM
I believe this will record anything that has EP in it not necessarily Id's beginning with EP. The way slugger indicated it will not record anything with EP followed by a number.
In your case it will record anything with EP even if it is a letter or Number. So if you have an Episode that begins with SH and the letters EP are any where in the description etc... it will record it.
Old 10-17-2012, 11:12 AM
Thanks for the replies but adding "EP\d+" did not work nor "EP*".
As a simple test I looked at the ShowID of upcoming shows that has both EP and SH ShowIDs and entered a favorite keyword with a known EP ID (EP7753700162) in both qoutes and without quotes, making sure to set the Search All Fields. Clicking on the Additional Airings button for this favorite gives me a "No airings or videos were found" message.
This leads me to think that the ShowID field isn't one of those keywords that SageTV interrogates.
If one of you guys can do a simple keyword favorite with just the EP###### of a known show in your program and let me know the results I would greatly appreciate it.
Old 10-17-2012, 01:14 PM
Seems to work for me, which is good because I use this trick on a lot of my syndicated favs to ensure I only record known episodes and only record them once.
Twitter: @ddb_db
Old 10-17-2012, 02:49 PM
I'll have to check this out later tonight. I've been doing it this way for a while with 6 shows or so (all kids shows from Nick and Disney) and haven't had one record with a SH Id yet. Everything you stated makes sense though. Maybe I'm just lucky.
Old 10-17-2012, 04:08 PM
Thanks for the verification. For some reason it doesn't work on my machine. Are you running Sage as a service and/or in any type of compatibility mode?
I'm running 6.6.2.218 version but a search thru the forum indicates others have tried and succeeded even before this version.
Old 10-17-2012, 04:29 PM
I run as a service, but that's irrelevant (or at least is should be). The major difference is I'm running 7.1.9. Who knows? There may be a bug in the version of v6 you're running. All I can say is that it works in v7.1.9.
Twitter: @ddb_db
Old 10-18-2012, 08:03 AM
That sounds right. I currently only have two favorites showing upcoming airings with SH id's. Neither includes EP anywhere in the generic desricption that is included....so my solution is only working because I'm lucky.
I did change the keyword on one of the favorites to Slugger's EP\d+ and it only picks up episodes with an EP id. I have not included qoutes on any of the keywords yet. I forgot to test it with the quotes...What do the quotes do? Without the quotes am I just lucky still.
Old 10-18-2012, 10:17 AM
I thought I remembered reading somewhere at some point that the quotes were necessary for Sage to recognize the string as a regular expression. But if it's working without the quotes then you should be fine. If that string were being treated literal then you would never match anything, unless a description, title, episode, etc. had the literal characters "EP\d+" somewhere, which no show ever would, presumably. The fact that it still matches airings without the quotes means Sage is still treating it as a regular expression.
Twitter: @ddb_db
Old 10-18-2012, 03:34 PM
Problem Solved!!
Migrated back to Java 6. Didn't help. Migrated to V7 and this didn't solve it. I've been running the SageTV server in XP compatibility mode (to ensure STV updates). I turned off compatibity mode, restarted SageTV and the EP\d+ stuff now works.
BTW: V7 looks much nicer but I think I've turned into my father. You know, Change Is Bad! I could easily go back to V6 but I think I'll stay and embrace change. I've upgraded one client in my office and I better get the HTPC up and ruuning before the wife and daughter get home.
One more thing. Love that you can take an existing (title) favorite and add a keyword, something lacking in V6.
Recording options rnadeau Phoenix 0 09-27-2011 03:55 PM
Explain recording options, Please airmech737 SageTV Software 2 07-13-2008 01:34 PM
Recording options –A little confusing FreeBSD4me SageTV Software 26 11-04-2004 02:41 PM
Intelligent Recording Options Possible? McTurok SageTV Customizations 3 07-19-2004 05:48 PM
Intelligent Recording Options Crowdx42 SageTV Beta Test Software 1 03-16-2004 02:28 AM
