Old 11-20-2013, 09:45 AM
Muchacho Muchacho is offline
Colussus and WHS
Hi-
My old HD PVR seems to have died and we are in need of a new tuner for the cable box. I am running WHS- the original one I believe. Are drivers available for the Colussus and does it work?
Thanks, Mike
Old 11-20-2013, 10:01 AM
mundale2530 mundale2530 is offline
I had no problems with Colossus and WHS v1. Cut the cord a couple months ago so I no longer have that setup.
Old 11-20-2013, 12:47 PM
I suggest you record to component like with HD-PVR and maybe in stereo rather than 5.1. The Colossus has problems for me with recording HDMI and 5.1 audio. Not using WHSv1 but at least in theory that shouldn't matter. YMMV.
Old 11-21-2013, 08:05 AM
Thanks. The card is ordered and should be here today. Appreciate the input
Old 11-21-2013, 11:58 PM
Dave Beddows Dave Beddows is offline
You may want to check this post out if you have problems setting it up
http://forums.sagetv.com/forums/showthread.php?t=59718
SateTV Hauppauge Colussus Quality Settings not working rfd Hardware Support 0 04-04-2013 08:36 AM
Audio issues with Colussus BrianDC Hardware Support 1 08-16-2011 03:13 PM
SageTV 7 no HDMI Capture? Colussus not supported? STEVON Hardware Support 45 03-21-2011 07:17 PM
