Old 07-27-2006, 10:18 PM
hummedan hummedan is offline
Unable to connect via internet but LAN OK
Hello all,
I am having a problem connecting to my placeshifter via the internet connection. I have been able to do this very regularly in the past; however, now when I try to connect to my server I get an error message telling me to make sure my server is configured correctly. I can connect without any problems over my wireless LAN.
My port forwarding is still enabled on my router and my firewall is set to allow sagetv and sagetvservice through. I am currently running v5.04.92 w/ Malore v3.13 stv.
I have read that by using the older STV, I can no longer see the place shifting option on my advanced setup menu which is true. I have tried to reload the sagetv3.xml file but I can't see it as an option on the menu although the file is indeed there.
I edited the sage.properties file per a message in the forum to:
STV=C\:\\Program Files\\SageTV\\SageTV\\STVs\\SageTV3\\SageTV3.xml
but the stv file continues to load and I can't get to the configuration options.
HELP
Old 07-27-2006, 10:24 PM
If that is the correct path to the SageTV3.xml file... since you are using service mode, make sure you are editing sageclient.properties.
If you can connect via LAN, then the PS options are at least enabled. But, in the default STV, you will be able to check the internet connection settings & manage the PS users.
Perhaps check that the server's local IP address hasn't changed & port forwarding on the router points to the wrong address now.
Old 07-27-2006, 10:55 PM
OK.. by editing the sageclient.properties I was able to get the xml file to load and get the placeshifter config wizard option again. YEAH!
When I go in and test the connection, it says it was able to connect to the IP addressregistered for the locator ID, but it could not access the server's port. I have checked my router and the port is open and it is pointing to the servers (static) IP address.
Now I have lost LAN connectivity after running the wizard.
GRRR
Any thoughts?
Old 07-28-2006, 05:40 AM
Because of this, I would double check your firewall settings on the server. Perhaps not all the required ports are open. Check the ports in this FAQ.
You haven't modified it to use a custom port number X, have you? If so, it may say that you'll need to forward port X to 31099 at the server's address. The LAN connection would still connect to 31099, though, I believe.
Old 07-28-2006, 07:26 AM
I am not using a custom port number, just 31099. I have even tried putting the servers IP address into the DMZ on my Dlink router which bypasses all router firewall settings and still nothing.
Also I have tried connecting with my zone alarm software firewall turned off, and no joy.
Both LAN and internet connections are now unable to connect.
Is there a way to completely clear the placeshifter settings? Would a re-install do anything? I would hate to lose all my other settings and favorites as they work great.
How now?
Old 07-28-2006, 07:44 AM
You could try removing all the 'placeshifter' and 'miniclient' related properties in sage.properties. (Make a backup first.)
You don't have a 2nd SageTV server running somewhere, do you?
Unless someone else has a suggestion, you should contact tech support. I've run through all the basic stuff I can think of at the moment.
Old 07-28-2006, 08:56 AM
Nope. I am running 3 tuners on my server (1-Hauppauge PVR-350 & 1 Hauppauge PVR-500) but only one instance of the Server software. I also am using a media MVP which is running fine. I have two MVP licenses, so that should not be an issue.
Old 07-28-2006, 10:52 PM
OK.. Problem solved. I un-installed and re-installed and the problem went away. After doing this, I now have a new placeshifter ID and everything works again.
Nothing like pulling out the old shotgun fix!
Thanks for all the help! I really lthing this is a great product and it has become part of my daily life.
