success : sagetv network encoder
According to the manual, a second instance of SageTV server can be used as a network encoder (see excerpt below)
The question I have is how do I setup network encoders? Are the steps: 1. Install SageTV server on remote machine (will become network encoder) 2. Setup video sources on the remote SageTV server(network encoder) as normal 3. Verify the video sources are all working 4. Stop the SageTV service and set the "enable_encoding_server=true" 5. Add "network_encoder_discovery=true to the main SageTV server (clients connect to this) 6. Add the 'discovered' videos sources for us by the main SageTV server Is this process correct? Does this mean for instance I can install a HDPVR remotely using EXEMultiTunerPlugin for tuning and the video source will be available to use on the main SageTV server as if it were local? Quote:
Oh all this is theoretically possible.... If you have an extra license key laying around
I have extra licenses. What I dont know is if that is the correct procedure.
If it is then I should be able to migrate/convert my existing 32-bit 2003R2 SageTV server to a network encoder with little effort (simply setting "enable_encoding_server=true" ) and put a new 64-bit Windows 2012 SageTV server in place. Does anyone have experience setting up SageTV Network Encoders using this procedure? (not the old sGraphRecorder). Thanks in advance. |
Any one know if this approach is correct?
It does seem like a lot of work for such a small payoff in increased speed.
Not doing it for a tuning speed increase.
The worthwhile goal is to separate out the video sources which have 32-bit dependencies and have to be physically attached to hardware (ie Cable or Satellite receiver, HDPVR, Ceton Tuning Card) from the sagetv server which does not. That way I can always upgrade the main sagetv server OS versions and hardware independently which has large impact on overall performance/flexibility. For instance right now stuck on W2003 R2 (because of these dependencies) which is much worse than W2012 which has faster network performance, handles multithreading / multi processors tremendously better, works with SSD trim, support modern CPUs/hardware etc |
Hey,
Yeah this process works for network encoders - pretty straight forward really I configured it like this yesterday for my home setup. The only issue I am having is trying to get the EPG to show data. (OTA EPG in Australia). For some reason when using the tuner card locally the EPG is fine, but when its configred as a network encoder, all I get on the master box is "No Data". |
Thanks for the feedback.
When the SageTV server 'discovers' the network tuner does it not appear as a video source that you can 'add'? As such should you not be able to associate a channel guide to the source on the SageTV server (for the remote source)? |
After you have 'discovered' and 'added' the network encoder to the SageTV server worst case you should also be able to manually edit the video source in the sagetv.properties file to associate a channel guide/ EPG with it, correct?
Please keep updating this topic with your results, I may end up going the network encoder route as a way to deal with adding a crappy Colossus or two onto an otherwise stable SageTV setup.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.10.3, sagetvopen-sagetv-server-opendct-java11 Docker (version 2.0.6) Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls |
I have the two servers up. The one that is the network encoder is configured with "enable_encoding_server=true" and the main sagetv server is configured as "network_encoder_discovery=true"
The main sagetv is not showing any "discovered" network tuners... The video source is configured and working on the network encoder server just not showing up in the main sagetv server. Any ideas? |
success! will report back with more details shortly. steps above work.
Now have a W7 x32 machine running SageTV 7.19 server acting as a network encoder.
Provides a seamless tuner that appears local though it is really a HDPVR connected to a Comcast STB using FireWire channel changing via MultiEXETuner on the remote SageTV server. The encoder is added like any local video source and associated with an EPG configured locally. The server is an old shuttle SK41g 1.8Ghz AMD Duron and 2Gb of DDR 266 and UATA hard drive with GigE PCI NIC Network bandwidth usage is less than 5% (1080p is max 19.2 Mbits = 2.4 MBps). And CPU usage is a startling 2% !! Should easily be able to support multiple HDPVR/STB streams. Another fine example of why SageTV is simply unmatched. |
Have you manually tweaked out your SageTV properties file yet to max out the HD-PVR recording bitrate? I don't believe you can achieve max bitrate any other way.
http://forums.sagetv.com/forums/showthread.php?t=33407 |
Will the remote hdpvr now being a network encoder does it exhibit the behavior of network encoders of pausing between the end and start of a show on the same channel? When using local video sources sage 7 added in the feature of continous recording between shows on the same channel that eliminates the pause. (not really a big deal, but it's a nice little perk)
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 12-30-2012 at 10:56 AM. |
I have been running 2 HDPVRs for years at 5.9GB/hr and the picture quality is excellent. Not sure that moving to 6.6GB/hr is a major improvement? But is looks easy enough to do... maybe i'll give it a shot. Looking at the thread - it looks like using VBR will actually make the stream rate even lower. Quote:
The configuration I have right now for my experiement is: recording: |
I'm getting the feeling from wbarber that this delay isn't any different from the Firewire channel changes. So, what is the channel change time exactly, via firewire?
I noticed that SageTV with USB-UIRT changes the channel in less than 1 second on the STB, but it takes the STB + HD-PVR another 4 or 5 seconds before the big blue light comes on and it starts recording. By the time I select 'watch' from the guide, I would say I'm typically looking at about 7 to 8 seconds before the image appears in Sage. |
Enabled the VBR 6.6GB/hr setting using:
mmc/python2_encoding/H.264-BestVBR=videobitrate\=13500000|vbr\=1|outputstreamtype\=1 Works like a champ. Now network utilization is .88% on the encoding server. Looks like when the network encoder is discovered it adds the following entry (which I believe can just be added by hand for other encoders instead of discovering): Quote:
I use the HDPVR only for channels that are not "copy freely" and need to be 'captured' instead directly from the STB. Otherwise I use either my HDHR Prime or Ceton tuners. |
Network Encoder Crashes SageTV | klutzy | SageTV Software | 5 | 02-09-2009 07:44 PM |
Tivo HD as a SageTV network encoder | inseattle | Hardware Support | 1 | 03-06-2008 11:47 AM |
SageTV Recorder as a Network Encoder | chewskydoo | SageTV Recorder Software | 4 | 12-26-2006 12:55 PM |
SageTV won't use network encoder [but setup ok] | IVB | SageTV Software | 1 | 05-07-2004 09:53 PM |
