Old 07-14-2020, 09:18 AM
bigbill's Avatar
bigbill bigbill is offline
Noticed something I had never seen before on SD
I am heading for Monterey in the Motorhome tomorrow and was setting up my lineups prior to arriving. When I was scrolling to pick the provider Local OTA, I noticed Hulu-Monterey, Philo-National, Youtube-national and other over the internet providers. Is there a tuner that can record from those providers over the internet?
If not, I wonder why those are choices? Does some other system have that capability? Thanks, Bill
Wouldn't LOCAST.org be cool..
Home DVR: SageTV v9.2.2(64)
i3-6100 3.7ghz, 4GB RAM, Win10 Pro, 3 small fast SSD +1@6TB WD Blue, 1 Quad HDHR, ( OTA Winegard HD8200U, CM4221HD), 1@ STP-HD200, 1@ Nvidia Shield , 1 @ Nvidia Shield new round, 70", 55" & 40" Sony's
RV DVR: 2@SageTV v9.2.2, NUC8i5BEK 16GB, SS980Pro NVMe, 5TB Passport, 1@olderNUC, 2 Dual HDHR, , Winegard BatWing, 40", 32", 28" Sony's, Max Transit
Old 07-14-2020, 11:13 AM
jpwegas jpwegas is offline
Bill,
In theory you could do use something like a Roku + HDPVR2/Colossus with OpenDCT and a custom tuning script to use those services as another tuner.
I don't know if anyone has tried that.
I got a Roku recently to play with but have not used it yet.
The choices are there because Schedules Direct gets a list of all lineups from its provider. It doesn't know which ones Sage can use or not, and Sage doesn't filter them when you select.
--John
Old 07-14-2020, 11:34 AM
bigbill's Avatar
Thanks! I just wanted to make sure I wasn't missing something, that for a traveler could be very helpful recording shows when there isn't an OTA towers in range. -Bill
Old 07-14-2020, 12:40 PM
I take back my earlier comment. I just remembered @will has done something like this with Philio.
See: https://forums.sagetv.com/forums/sho...8&postcount=10
--John
just checking logs for fun, and noticed the Gemstone log is full of this: SomeWhatLost Gemstone for v7 5 01-23-2017 12:34 PM
I just got a noticed for an HD 300 beta firmware update rdefino SageTV Media Extender 1 08-06-2012 04:12 AM
Some edl files not being noticed wado1971 SageTV Customizations 8 01-02-2009 07:58 PM
Just noticed this problem lovingHDTV SageTV Software 3 11-12-2004 09:32 PM
