Old 08-07-2019, 06:57 PM
HDPVR Issue after 9.2.1 Upgrade
I upgraded both Opendct (which I use with SiliconDust devices) and SageTV to the latest versions this evening. After this was completed My HDPVR will not work as it did prior to the upgrade and I am receiving a (1016,0x13) Audio Compression error in SageTV. Any thoughts on why? I am dead in the water with the HDPVR Tuner......
Old 08-08-2019, 09:11 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
Oh no! After three weeks of fighting my v9 x64 of SageTV, I was ready to, this morning, install OPENDTC. I have no problems right now but am convinced that OPENDTC is the way to go. I guess I better wait to see how this shakes out before proceeding.
Old 08-08-2019, 10:49 AM
UgaData's Avatar
UgaData UgaData is offline
OpenDCT (and the older SageDCT) are really meant for CableCard tuners. It just so happens that there are few additional uses for OpenDCT with some of the HDHR OTA tuners.
OpenDCT would (should?) have no effect on an HDPVR device.
My first shot in the dark for OP, double check what Codecs/filters are being used for audio.
Old 08-10-2019, 09:15 AM
Thanks for the responses. I totally agree that the OpenDCT (which has been rock solid for HDHomerun Primes) should have no impact on the HDPVR. I just believe the only things that changed prior to this issues showing up were the upgrades of the OpenDCT and SageTV to the latest.
For some further clarification I am running SageTV 64 bit on a ubuntu linux box which has also been very stable and reliable. So I was a bit surprised when I ran into these issues. I built the SageTV Linux server sometime back as a Linux Newb which I still am, though better than Day one. I was hoping someone would have run into this before and it would be a simple fix but maybe not.
For anyone with Linux Experience could you point me in a direction which will help me check if the 1212 HDPVR is actually running properly under Linux? I think I need to start there but have not found any details on how to check that!
Thanks in advance!
John
HDPVR issues after v9 upgrade 4T2 SageTV Github Development 32 11-12-2016 08:26 AM
HDPVR Audio Lag Issue SDeGonge Hardware Support 10 07-16-2016 08:32 PM
Ubuntu 10.04 HDPVR IR Blaster Issue lyroy SageTV Linux 12 06-16-2010 07:21 PM
Bad HDPVR or some other issue? pat_smith1969 Hardware Support 5 10-20-2008 01:09 PM
HDPVR Intermittent Issue dadof4 Hardware Support 1 09-23-2008 06:04 AM
