Old 08-10-2019, 01:19 AM
maninblack_30 maninblack_30 is offline
SageTV x64 win HDHomerun no channels found
Hello everyone, I have been running SageTV for years now (since v6) and recently had to build a new server....I'm in Australia using OTA tv and 2 HDHomeruns...when I install the x86 version of sage v9, the HDHomerun setup app lets me choose "SageTV" as it's BDA profile, and I then scan for channels in SageTV and all is good...however if I install the 64bit version of SageTV the HDHomerun app doesn't notice Sage is installed and doesn't offer SageTV as an option... I'd really like to run the 64 bit as a matter of principle, does anyone have any ideas?
Ta,
Fraser
P.S. I'm absolutely over the moon to see Sage continue, this is the first time I've used v9, since I installed v7, and i'm really happy to see it working well!
Server:HP DL380 Dual Quad Xeon E5530 2.4Ghz per core, 64GB RAM, 2x Hauppauge HVR-2200 tuners (4 total) 146GB mirrored system drive running Server 2012 R2, 3TB storage HDD space (7x500Gb),
Clients:1 STX HD-100, 1 HD-200, 1 HD-300 for main TV room connected to Pioneer SC-LX72 with Tannoy MX4 mains, MX3 rears and MXm centre (or center!) and Yamaha YST-SW160 subwoofer, Bravia 55' LCD
Old 08-10-2019, 07:55 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
See my (quite lengthy) thread on this subject... or skip to the very last post. https://forums.sagetv.com/forums/sho...t=66040&page=3
Old 08-10-2019, 08:38 PM
Smile
All good now, thanks for your replies, it worked when I had both x86 and x64 installed and the x86 running NOT as a service when I fired up the HDHomerun software, then selected SageTV in the setup utility, then shutdown x86 and started x64 NOT as a service, scanned for channels, then shut it down and fired up the x64 service and did the rest via my HD300
Thanks again!
Old 08-10-2019, 09:31 PM
RonBoyd's Avatar
Thanks again!
Glad I could help... although I was, after all, standing on the shoulders of giants.
HDHomeRun Prime No Channels Found chairmanmao Hardware Support 10 02-11-2019 05:35 PM
SageTV enables more channels than are found on HDHomeRun PredatorVI Hardware Support 2 03-21-2010 11:51 PM
Hauppauge HVR-950q OTA no tunable channels found with SageTV scan but works with MCE MXMike Hardware Support 2 02-12-2010 04:09 PM
HDHomeRun not found Nutball Hardware Support 3 11-01-2008 08:37 AM
HDHomerun and no channels found/no signal problems queequeg99 Hardware Support 8 06-12-2008 11:00 AM
