View Poll Results: Are you interested in this? Will you ever use it?
Yes, I waited for this a long time! Thanks a lot! 11 34.38%
Well, I will try it. Let's see how it works. 12 37.50%
Maybe, until SageTV fixes this and releases a portable version. 5 15.63%
No, I do not need this or a portable version. 4 12.50%
Voters: 32. You may not vote on this poll
Old 07-23-2007, 01:16 PM
owilsky's Avatar
owilsky owilsky is offline
Portable Placeshifter for Windows
This is more of a workaround, because the SageTVPlaceshifter.properties will still be written into the profiles folder, but it will be deleted after Placeshifter exists. It will then be moved to the Placeshifter folder on the USB drive.
- download zip file below
- Extract SageTVPlaceshifterPortable.exe into a folder on the usb drive
- Create subfolder "App"
- In this folder "App" create two new subfolders: "JAVA" (optional) and "SageTVPlaceShifter"
- Optional: Copy the folders "bin" and "lib" from an installed JVM into folder "JAVA". If you won't do this, a JVM must be installed on each computer you run the portable PlaceShifter.
- Copy every file from an installed Placeshifter into the created "SageTVPlaceShifter" folder
That's it.
I used the Portable application template created 2007 by Karl Loncarek, please see http://portableapps.com/forums/devel...pp_development for more information.
Oliver
V0.1 initial version
Oliver Kötter
Check this thread for importing German TV Data into SageTV
Using SageTV 7.1.9, Java 1.6.0_24 Win7 Home Premium on an
Asus M4N78-AM Mainboard, AMD Athlon II X2 215, 4 GB RAM, 500 GB HDD, 2xTechnoTrend S-2400 as Network Encoder (LM DVB Smart Recorder), ATI Radeon HD 3450 with analog TV-Out on good old CRT TV (100Hz)
My avatar shows the world's best composer!!!
Old 08-01-2007, 05:31 PM
rickgillyon's Avatar
I can't believe you've had no responses on this. Great idea. I've set it up and it seems to be working perfectly so far, great job! I'm going to try it from work tomorrow...
Old 08-01-2007, 07:54 PM
gblinckmann's Avatar
gblinckmann gblinckmann is offline
Thumbs up
I've been running PlaceShifter from my thumbdrive for a while. I know it's not truly a "portable app", but it was the best way I knew how to do things. It's good to know someone's working on making this setup better.
SageTV v6.4.5 - Windows Vista Home Premium
HP m8200n, Athlon 64 X2 6000+, 3GB RAM, 3 500 GB SATA/300 7200 RPM HDD's
(2) PVR-150MCE's - (1) HVR-1800 HD ATSC/NTSC - (2) MediaMVP's - (2) STX-HD100's
Old 08-02-2007, 01:19 PM
GKusnick's Avatar
GKusnick GKusnick is offline
There doesn't seem to be a choice for "Yes, I use portable Placeshifter, but no, I don't need this workaround."
See here for an alternate workaround that doesn't require any additional software.
-- Greg
Old 09-07-2007, 12:08 PM
CioccRider CioccRider is offline
What I was looking for.
I'll be trying this out at work later this weekend. The network and machines out there are pretty well locked down, so I don't hold much hope, but I'll let you know how it works.
I've the feeling we're going to have some firewall issues.
Keith in Spokane.
Old 09-07-2007, 12:30 PM
owilsky's Avatar
FYI: for the latest beta of PlaceShifter you don`t need this anymore...
Oliver Kötter
Old 09-11-2007, 10:40 AM
Khristopher Khristopher is offline
What advantage/difference is there using this method instead of the one found here? http://forums.sagetv.com/forums/showthread.php?t=17728 (The downloadable zip file)
Old 09-11-2007, 11:00 AM
owilsky's Avatar
You still need the files described at that thread. But if you put the files on a USB stick, the configuration files won't be saved on USB but on the client computer.
The above posted software moves it pack to usb.
But this is not necessary anymore, the new beta of Placeshifter can use a properties file that is in the same folder as the rest of Placeshifter.
Oliver Kötter
Old 09-11-2007, 01:31 PM
GKusnick's Avatar
Also note that that zip file hasn't been updated in over a year. Your best bet is to install the current version of Placeshifter to your hard drive and then copy the Placeshifter folder to your USB stick.
-- Greg
Two placeshifter clients on one PC? Fountainhead SageTV Placeshifter 2 01-08-2007 04:08 PM
Improve Placeshifter PQ over LAN? zubblwump SageTV Placeshifter 7 11-06-2006 04:21 PM
A Couple Placeshifter Questions zubblwump SageTV Placeshifter 0 09-24-2006 08:42 AM
MP4 and Placeshifter codacoda SageTV Beta Test Software 21 06-17-2006 01:24 PM
SageTV V4.1.11 Beta Is Available - Better Placeshifting! Narflex SageTV Beta Test Software 81 04-04-2006 09:39 PM
