Old 06-23-2005, 08:35 AM
digitalgm digitalgm is offline
Commercial processing not happening
Hello all, I have the Cayars 18E installed and I Have commercial processing enabled all the ways I think I can but it still isnt processing my shows. What gives? Is there a way I can check to see what the settings for it are outside of sage?
AdamR
Currently building the mother of all SageTV Installations .... XXL SageTV
Summary: 40 Analog Tuners, 10 OTA HD Tuners, 3 Sat HD Tuners, 20 Client HTPCs, Dedicated Commercial Skipping Server Wish me luck!
Old 06-23-2005, 10:53 AM
Did you also download comskip and place it in the Sage TV directory? Please read the comskip thread for more help.
Old 06-24-2005, 08:41 AM
I did not download comskip as I believed it was already included in this STV. I have been able to do manual commercial skipping without any error.
AdamR
PS - when does the commercial skip get triggered? Is it after the show has been recorded? I ask because I turned on the option to commercial skip automatically and it has not touched my previous recordings - should it or do those have to be manual?
Old 06-24-2005, 09:42 AM
Did you download Just the STV? You need to get the Java and Core files as well as the STV to get the entire package on a first time install (I.E. not upgrading from Cayars 17) - I believe.
Old 06-24-2005, 09:45 AM
ToxMox's Avatar
ToxMox ToxMox is offline
Have you tried simply quitting the Sage interface and re starting it? I found when using internal comskip in any STV that the comskip processing won't work properly after changing STVs or settings until restarting the interface.
Old 06-28-2005, 08:06 AM
I have restarted Sage numerous times and I still believe the commercial skipping is not happening. I will add that I can do it manually though and I have all the required files.
AdamR
