Old 02-26-2007, 08:22 AM
mike400hp's Avatar
mike400hp mike400hp is offline
Send a message via MSN to mike400hp
Over-Air HD and Basic Cable Mix
Hauppauge has a new WinTV-HVR-1600 tuner that will let you receive both cable channels are over the air HD. In my situation most of the local channels are available in over the air HD, but I also want to be able to tune to my basic non-HD cable channels. Is it possible to configure the SageTV program guide to use the HD receiver for local channels and then the cable receiver for all the other channels? I want to seemlessly surf between standard format and HD.
Old 02-26-2007, 09:36 AM
Goodspike's Avatar
Goodspike Goodspike is offline
Not quite the same thing, but with the HD Homerun, the HD OTA channels and the HD QAM channels appear as one channel (they don't duplicate) and are part of the same channel list, so based on that I think you can do what you want.
HDHomeRun success story jbarr Hardware Support 9 02-22-2007 04:46 PM
