Old 09-14-2008, 08:54 PM
ikurtram ikurtram is offline
Question No channel listing for OTA-HD channels received on Cable.
Background:
I have Extended Basic Cable service from Insight Communication. My cable company also transmits the local OTA HD channels in addition to the regular analog cable channels.
My Setup:
  1. Hauppauge PVR 350 - Cable connected to TV tuner - configured to use "Insight communications" cable line-up
  2. Hauppauge HVR 1800 - Cable connected to Digital tuner - configured to use "Lexington - Digital Broadcast" OTA line-up
Issue:
I'm not receiving any channel data for the 4 HD channels that I receive on Hauppauge HVR 1800's Digital tuner.
So, I looked at the FAQ and found this text:
The channel may be over-the-air (OTA) only. The guide data for OTA broadcast stations that are not also part of a cable or satellite lineup from Zap2it is not available to SageTV. Most OTA stations are also carried by cable or satellite companies as part of their local channel coverage, so the guide data for most OTA stations is thus available to SageTV. However, there are some stations that are OTA-only. Listings for such a channel will only be available if it is a digital station that includes EPG data within its broadcast.
My case is close to this, but none of the 4 OTA HD channels I'm having issues with, are OTA only. There are analog versions of them that I also receive on my PVR350 tuner. Is there a way for me to tell Sage to use the line-up for the analog channels for these HD channels? Or is there any other way to change my channel setup so that I get channel listing for the 4 OTA HD channels?
Old 09-15-2008, 10:23 AM
CollinR CollinR is offline
You actually don't want OTA (ATSC) streams you want QAM.
In the setup choose Cable, choose the top tier of cable programming in your area.
Now in channel setup choose to unselect all, then do a channel scan.
The QAM tuner will find the QAM cable rebroadcasts of the ATSC originals.
The confusion comes from this being over cable not OTA anymore even though it is the same channels as available OTA.
epg, ota
Combine OTA and cable channels in guide? popechild SageTV EPG Service 6 08-21-2007 06:12 PM
Multiple tuners, multiple guide channels? Polycron SageTV EPG Service 2 06-02-2007 04:33 AM
Jacksonville Comcast Lineup - Lost HD Channels MTuckman SageTV EPG Service 1 04-10-2007 09:51 AM
HDHomeRun success story jbarr Hardware Support 9 02-22-2007 04:46 PM
Default to record HD channel Bug dj7675 SageTV Software 4 02-19-2007 07:47 AM
