Old 09-13-2009, 10:23 PM
kfontenot kfontenot is offline
OTA Channel 13-1 showing incorrectly
I am having problems with one of my OTA channels. Channel 13-1 (Physical # 32-13-1) is actually showing what is on channel 49-1 (Physical # 32-49-1) instead of 13-1. I am running the latest version of SageTV 6.6.2 in Vista Ultimate 64 bit. How can I fix this problem?
Old 09-13-2009, 11:19 PM
What tuner are you using?
Have you run a channel scan in Channel Setup for that tuner?
Old 09-14-2009, 04:44 PM
I have a Hauppauge HVR-1600 as well as an ADS Instant HDTV tuner. I have tried a channel scan multiple times but nothing changes. This started happening right after the digital transition, but I never looked into it until now. The channel worked just fine before the transition.
ATSC OTA and Cable Channel Confusion-OTA, HD-PVR, & SD Savage1701 SageTV EPG Service 0 09-06-2009 07:50 AM
Changing channels but always showing the same channel? JonSS Hardware Support 2 08-13-2008 01:09 PM
Channel Lineup - Not All Channels Showing mpcrider SageTV Software 2 02-18-2008 09:59 AM
Analog channel 44 not showing in guide? snoopy SageTV Software 1 07-13-2007 01:51 PM
Channel 8 is showing channel 13, channel 13 shows channel 13 AWS SageTV Software 2 01-28-2005 01:38 AM
