Old 06-12-2010, 08:25 PM
alwzn4vr alwzn4vr is offline
SageTV install location drive failed
So I had sagetv installed on my dedicated server on d:\sagetv
This drive failed but has no media on it. Solely the sagetv installation. I replaced the failed drive and had a backup of the drive. Not all that recent but whatever.
So, I've had to add some favorites that weren't added since the last backup. But, not all the files that are in the recorded location (E:\Recorded) show up in when I go to 'SageTV recordings'
In other words, the files are there but Sage is telling me otherwise. I can browse and view them manually but this will cause confusion amongst the other other members of the family. I know you can refresh imported media, is there a way to 'refresh' recorded shows.
Old 06-13-2010, 02:06 AM
GKusnick's Avatar
GKusnick GKusnick is offline
The recording database (Wiz.bin) is stored in the SageTV installation folder. If you lose that, your recordings will show up as imported videos. That's why it's important to make frequent backups of your Sage installation.
Without a recent backup, you'll need to use a third-party metadata tool to download airing information for those recordings and get them back into the Recordings list.
-- Greg
Old 06-13-2010, 07:15 PM
I guess I should schedule backups of wiz.bin
Is the wiz.bin file propietary format? You mentioned a 3rd party tools, are they to be found on this forum?
WHS: Drive failed. What did I lose? Duplication? kevine General Discussion 11 10-03-2009 11:42 AM
What drive for OS on a new WHS install? btrcp2000 Hardware Support 4 07-19-2009 07:53 AM
Which Drive to Install Sagetv Program on Electronicbuff Hardware Support 4 07-07-2009 02:16 PM
Failed to connect from remote location but connects at home craigap SageTV Placeshifter 24 01-02-2008 03:33 PM
Install location problems dervari SageTV Beta Test Software 3 03-30-2004 07:45 PM
