Old 10-26-2021, 10:04 AM
tvmaster2's Avatar
Spinning circle with new, 64 bit W10 install. Why...
Initially, the new, 64bit W10 Pro SageTV server install was quite slick.
Now, and more often, I'm getting the spinning circle of death when doing simple things like checking "View Recording Detail", or just FF or RW recorded video.
Any idea's where to check first for data backups, etc.?
It's possible I made a Properties change to help performance years ago on my 32 bit W7 install, but if so, I've forgotten what it was. Is that a possibility?
Anyway, anyone else having spinning circles using W10 64bit SageTV server software?
Old 10-26-2021, 12:01 PM
UgaData's Avatar
UgaData UgaData is offline
It could be several things. Could be a plugin.
I would check the Java memory setting. I am fairly sure you already addressed the java memory, but check what Sage actually sees - just to be sure.
Old 10-26-2021, 04:19 PM
tvmaster2's Avatar
Thanks - I set it to 4gb (4000) as soon as the system was up and running. One of the main reasons I jumped up to 64bit. Right now my heap is 295/492/3818
It's also a brand new system drive (500gb SSD), so that shouldn't bog anything down either. I'll take a looooooong look at my OLD properties file.
Old 10-26-2021, 05:13 PM
UgaData's Avatar
If you use extenders you may need even more memory reserved for Java.
Old 10-26-2021, 06:50 PM
tvmaster2's Avatar
Mostly, there's only one active at any time
Old 10-26-2021, 10:20 PM
wnjj wnjj is offline
4GB is probably enough for a dozen extenders.
Windows Installer
Old 10-26-2021, 10:27 PM
tvmaster2's Avatar
Thatís what I was hoping. So now I need to find another reason. Maybe itís searching my drives?
Old 10-27-2021, 04:34 AM
When I has spinning circles, it was one of the following:
  • Bad cable (Coax or Cat6)
  • Hard Drive starting to have problems
  • Power supply on HRHomeRun
I would start my checking the signal strength of the Coax cable, then running a LAN speed test, and drive diagnostics.
Servers: ChannelsDVR, Plex, AnyStream, PlayOn,
Tuner: HDHomeRun Connect Duo
Sources: OTA, Sling Blue, Prime, Disney+,
Old 10-27-2021, 07:10 AM
tvmaster2's Avatar
Thanks. Easy to change a cable, or disconnect the HDHomerun. Less so to lose a drive. Do you have a favorite drive-checking app? What about a failing network switch?
Old 10-27-2021, 08:30 AM
I use WD drives, they have a a utility called Data Lifeguard. Look for something similar from your drive manufacture.
I have almost never seen a switch fail. It is usually the cable. You can try switching ports and see if that makes a difference.
Old 10-27-2021, 08:38 AM
tvmaster2's Avatar
thanks
Old 10-27-2021, 09:31 AM
Looking back thru some old posts on this forum, there were recommendations to use Seagate's SeaTools for Windows. It works on drives from any manufacturer, not just Seagate.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.9.2, SageTV (java11) & OpenDCT Dockers
Firestick 4K: getting spinning circle hb4 SageTV Clients Development 0 06-25-2021 02:19 PM
Another spinning circle of death t4runnr SageTV Software 24 03-07-2014 10:37 AM
Spinning Circle - somewhat fedup Islander SageMC Custom Interface 38 04-21-2010 07:24 AM
FF and spinning circle (strange) bmac.to SageTV Software 7 03-09-2009 10:12 AM
