Old 04-24-2007, 09:41 AM
Xiggy's Avatar
Xiggy Xiggy is offline
MVP Model / Revision Questions
I've heard that the brightness issue has been corrected in newer revisions of the MVP - does anyone know the exact model/revision to look for? I'm looking for a wired MVP, not wireless. Is the Sage store selling the latest MVP's, or is it a crap shoot which revision I'd get?
xig
Old 04-25-2007, 08:04 AM
FidgetyRat's Avatar
FidgetyRat FidgetyRat is offline
I purchased a new MVP from amazon and got a very modern version with the digital sound output.
Not sure about the sage store. Every time I wanted to buy one from them they were out of stock and never restocked.
Server: 2.6Ghz Pentium Dual Core, 2GB RAM. 3x PVR-150, 1.5TB HDD. Geforce 7300GS, Sage 7.0.15
Client: Jetway ION-Top - Dual core ATOM 1.6 & NVIDIA ION
NAS: QNAP TS-419P 3.7TB Raid-5
Special thanks to tmiranda for making my 24h time format dream a reality. See here for more details.
Old 04-25-2007, 11:49 AM
tipstir tipstir is offline
Question
Can you tell us both which Firmware model do you have?
Old 04-26-2007, 06:53 AM
derelicte1 derelicte1 is offline
I received a revision h3 mvp to replace my rev d3a mvp I returned to hauppauge due to the brightness issue. It has the digital audio output and the brightness is fine. I believe that it is the latest version.
The revision of firmware seems to be irrelevant because it is reloaded when the mvp boots. If this was simply a firmware issue, it could have been fixed with software.
Old 04-26-2007, 01:25 PM
Question
You can returned them back HAU really and do they give you a replacement or something else in return?
Old 04-27-2007, 07:14 AM
yep. there is a whole thread about it:
http://forums.sagetv.com/forums/showthread.php?t=17806
Old 04-28-2007, 08:38 AM
valnar valnar is offline
I started another thread about the same subject. I just bought one from Sage and received it yesterday. Model 86019, Rev H3, Lot 1107
Maybe I'm picky, but I assume I have the problem described in other threads on this forum. The red's are overly saturated (orange'ish to me) and the brightness appears 15-20% down from the TV's regularl tuner. Cranking up the brightness on the recordings is not an acceptable fix to me, and if I do the same with my brightness/contrast on my TV, it doesn't really fix the detail of the dark scenes - it just makes it washed out.
I can't believe this is a problem that still persists.
Robert
Old 05-06-2007, 10:16 PM
stevech stevech is offline
Wish we knew if the video levels issue was present in every H3 unit or if it's some sort of design problem where variations in component tolerances (like transistors or resistors) is the reason some work properly.
Old 05-07-2007, 07:37 AM
Taddeusz Taddeusz is offline
Mine works fine and it's an H3. My guess would be that people still complaining about dark video probably need to better calibrate their tuner inputs and/or TV.
Old 05-08-2007, 05:03 AM
Uh, no. Either your blind or your unit is not affected. My setup is calibrated.
Robert
MVP and Powerline Networking: Incompatible? mdnttoker SageTV Media Extender 24 11-07-2007 12:11 AM
MVP - Latest revision Armondole SageTV Media Extender 5 03-08-2007 08:59 AM
MVP Extender Questions: Power and Volume geogecko SageTV Media Extender 9 01-29-2007 02:13 PM
SageTV software with Hauppage MVP problems continued dbritton SageTV Media Extender 4 11-07-2006 06:59 AM
MVP Never Progresses past "Starting Application" MrApollinax SageTV Media Extender 49 01-03-2006 04:25 PM
