Old 12-13-2007, 06:23 PM
73cuda 73cuda is offline
Screen flashing Pink ???
Hi,
I have a 6200 PCI card in my Gateway 835GM Dual core 2.8ghz with 1GB ram, XP Media Center Edition 2005 OS. Sony monitor connected with the VGA cord.
Also have a PVR-500 tuner card.
I'm running Sagetv 6.
Problem I'm having is every few seconds the display flashes a hot bright pink, like a strobe.
It did not do this before I installed this 6200 card.
Has anyone had this problem before ?
Old 12-13-2007, 07:31 PM
I don't know if yours is the same issue, but I saw something like that on an older PC when the video cable was loose.
Old 12-13-2007, 07:47 PM
Thanks Andy but I have the vga cable screws tight and it does it using S-video out too.
Old 12-13-2007, 09:08 PM
sainswor99's Avatar
Do you have another computer nearby? It could be a number of things:
1. The monitor is going bad. Try hooking it up to the second computer to verify.
2. The video card is not seated properly. Pull the card out, blow some compressed air over the contacts to make sure everything's clean, and reseat it.
3. The video cable is loose, but you've ruled that out.
Stu
Old 12-14-2007, 08:09 AM
SHS's Avatar
SHS SHS is offline
Frist try sainswor99 idea
But if it still fail do you self a big fav and dump 6200 rigth long with 6500 there junk and know for having problem.
Old 12-14-2007, 11:25 AM
teknubic's Avatar
teknubic teknubic is offline
Send a message via ICQ to teknubic Send a message via AIM to teknubic Send a message via MSN to teknubic Send a message via Yahoo to teknubic
The VGA connector might be tight but it might also have a bent pin.
$.02
Old 12-14-2007, 08:33 PM
Thanks guys for the help, I did all you suggested and more and even spent an hour and ten minutes on the phone with BFG tech, the tech was very nice but after all was said and done he said I must have a defective card.
I agree and think it's not just my card, it's all the 6200's just as SHS said and I went to Best Buy today and got an ATI and it works perfectly.
I'm real happy now, no more stinking pink strobin, it was really screwin with my brain !
thanks again.
Media Extender screen loads on server shardinite SageTV Media Extender 4 09-26-2007 09:44 PM
MVP & Flashing Sage Screen pilotguy7ca SageTV Media Extender 16 11-07-2006 05:11 PM
Slideshow as a Screen Saver Narflex SageTV Studio 22 10-17-2006 06:35 PM
Thinking about buying + Line of flashing artifacts at top of screen? TabsAZ SageTV Software 13 10-16-2006 01:16 PM
MVP flashing SageTV logo screen polen SageTV Media Extender 35 06-13-2006 08:08 PM
