Old 01-25-2004, 07:19 AM
David Lawrance David Lawrance is offline
Full Screen?
There's no maximize button on my title bar, just close and minimize. How do I switch to a maximized display?
The full screen keyboard sequence doesn't do anything in this regard (shift-control-F.)
Old 01-25-2004, 07:30 AM
Are you talking about full screen TV-Control-V?
Old 01-25-2004, 07:35 AM
Guess not. The production version of SageTV has the standard windows buttons for close, minimize and maximize on nonmaximized screens. I left SageTV unmaximized when I closed it before installing the beta. The beta remembers my window size, but takes away my ability to maximize. I can resize it, but that leaves a titlebar.
Old 01-25-2004, 07:45 AM
falchulk falchulk is offline
If you have the PVR remote, use it to go to full screen. if not read the documentation to find the keystrokes that do it.
Old 01-25-2004, 08:49 AM
salsbst's Avatar
salsbst salsbst is offline
Ctl-Shift-F works for me. If it doesn't work for you then it must be a bug.
Old 01-25-2004, 09:15 AM
Colin Colin is offline
Double clicking the title bar in windows will maximize/restore any window.
Case: Shuttle SB61G2 | CPU: Intel P4 1.8A | Input: PVR-350 | Output: Onboard VGA -> Grand Ultimate XP Pro Component Video Adapter | HD: Seagate 160GB S-ATA
Old 01-25-2004, 10:03 AM
Okay, I really am nuts. There never was a maximize icon in the titlebar. I was hitting the icon in the Sage control bar. I'll have to give this another try.
Old 02-19-2004, 11:53 PM
dervari dervari is offline
I double clicked on the title bar, and now I can't get the damn thing to restore into a window. Any ideas?
Old 02-20-2004, 12:11 AM
ErsatzTom's Avatar
ErsatzTom ErsatzTom is offline
Send a message via AIM to ErsatzTom
Try Ctrl-Shift-F
t
Thomas Micheline
duff@sage-community.org
http://www.sage-community.org/
Old 02-20-2004, 07:06 AM
mlbdude's Avatar
mlbdude mlbdude is offline
If Ctrl-Shift-F does not work, make sure that is the key that is bound to Full screen in Advanced setup.
Old 02-20-2004, 10:45 AM
Maladin Maladin is offline
Send a message via AIM to Maladin
When I first installed the beta I could toggle fullscreen mode. As soon as I enabled the PVR 350 output, my monitor window dropped out of fullscreen mode and I can't make it fullscreen anymore, even when I disabled the PVR 350. Of course since I use the PVR 350 this isn't a major issue for me but its slightly annoying. (My monitor is in a different room and I like to watch on that screen occasionally.)
