Old 08-13-2009, 03:43 PM
cracklepopflash cracklepopflash is offline
Background Image Resizing question
I am just wondering if there are any function calls that can make the background image I am setting for my menu widget to fit within the display. Thanks. Also what are the best dimensions for an image to be used as a background image and can someone maybe give me a link to background image sources.
Old 08-13-2009, 03:58 PM
GKusnick's Avatar
GKusnick GKusnick is offline
You don't need any function calls to scale the background image. Just tick the Stretch Background checkbox in the Theme properties dialog.
I figure 1/3 to 1/2 of your TV's resolution is a good size for background images. Much smaller than that and you'll start to see pixelation when it scales up to full-screen size.
I either make backgrounds myself, or use Google image search to find them.
-- Greg
Old 08-14-2009, 06:36 AM
PLUCKYHD PLUCKYHD is offline
Google images is where I get allot images from using search large size for backgrounds
Background Image Scaling Problem bialio SageTV Studio 2 01-20-2008 07:42 PM
Background Image question broderp SageTV Software 3 04-11-2007 08:19 AM
Any EASY Way to Change The Background Image? joe123 SageTV Customizations 2 01-26-2006 09:23 PM
2.1.10 - TV not resizing or slow resizing when go between menu PIP to fullscreen TV ruel SageTV Software 0 11-04-2004 01:17 AM
Background image falchulk SageTV Software 2 10-28-2003 10:03 AM
