Old 08-18-2009, 10:41 AM
cracklepopflash cracklepopflash is offline
Full Screen Image Resizing
So when I go to full screen mode, my UI elements resize in such a way that makes it look quite different from when I am not in full screen mode. Everything seems not to be inproportion. For example, images that were relatively wide in not full screen mode are relatively narrower in full screen mode. How do I keep the relative sizes consistent when I enter full screen mode?
Old 08-18-2009, 12:01 PM
PLUCKYHD PLUCKYHD is offline
You need to keep them in panels widgest and size them accordingly to the size of the panel widgets that you want them to be. Remember that as the panel widget grows (ui changes) the size of the text or image will grow porptionally.
Old 08-18-2009, 12:49 PM
And make sure you've got your Display Aspect Ratio setting correct in Detailed Setup.
Background Image Resizing question cracklepopflash SageTV Studio 2 08-14-2009 06:36 AM
Full Screen mode does not use whole screen timg11 SageTV Software 13 06-02-2009 05:30 PM
Why should the sage screen saver only work in full screen mode? carlgar SageTV Software 9 07-16-2008 04:11 PM
2.1.10 - TV not resizing or slow resizing when go between menu PIP to fullscreen TV ruel SageTV Software 0 11-04-2004 01:17 AM
Full Screen? David Lawrance SageTV Beta Test Software 10 02-20-2004 10:45 AM
