Old 02-03-2010, 03:16 PM
gerberdude's Avatar
gerberdude gerberdude is offline
logos not transparent
Okay, so I've downloaded and put all of these logos:
http://forums.freytechnologies.com/f...do=file&id=211
in the channel logos folder, confirmed that they are the only logos in there, and that they are all png logos.
Somehow, there is only one that is showing up as transparent, all of the others have a white background.
What have I done wrong?
Old 02-03-2010, 03:24 PM
PLUCKYHD PLUCKYHD is offline
Is the background transparent or white? What are you using to edit them?
Old 02-03-2010, 03:36 PM
gerberdude's Avatar
Photoshop.
Umm yeah, I guess I could have checked on that. Apparently the backgrounds are white. Do I need to edit them and remove the white backgrounds before I put them in the logo folder? I guess I just assumed that someone would make them transparent since they are PNGs.
I mean, isn't someone else supposed to do all of this work for me?
Old 02-03-2010, 03:39 PM
gerberdude's Avatar
So the logical follow up is:
Can anyone recommend a package of logos that are already transparent pngs?
Photoshop.
Yeah you would think someone would huh
Yes the backgrounds need to be transparent not white so I would simply do a white to transparent.
Old 02-03-2010, 03:48 PM
gerberdude's Avatar
I guess I could do that in photoshop and just process them all as a batch, that way I don't have to screw around with them one at a time with the magic wand.
Any recommendations on how to do that in PS? (not using the magic wand)
Old 02-03-2010, 04:31 PM
markds's Avatar
markds markds is offline
http://forums.sagetv.com/forums/down...do=file&id=336
Pretty much done for you here. Direct TV transparent logos part 1 & 2.
Most of the png(s) are trans. You can pick some others up in the other logos packages offered.
hp intel quad 2.8Ghz 16GB ram Win 7 pro 64bit hauppauge 1250 usb/serial connect 15TR storage recording directv TRYING to get sageTV9 to install over 7 without the SERVICE keeping on blowing up
Old 02-03-2010, 07:13 PM
Also I would recommend trying gimp it is pretty easy to work with.
Old 02-05-2010, 10:16 AM
megamojo's Avatar
megamojo megamojo is offline
You might want to try it with a few and see how it looks first. I was super excited about transparent logos too until I actually made a few. Some looked great, but most looked god-awful. I ended up grabbing all my logos from here, so they all have the same black background and match each other. It's amazing how nice of an effect it is to have them all match each other.
http://www.iconharmony.com/icons/wat...ory=harmonyOne
Old 02-08-2010, 02:40 PM
gerberdude's Avatar
Yeah, after messing with this transparency, I think I'm going to ditch it and just go with the harmony icons. They are pretty sharp.
Do they have to be a certain size to work in the EPG, etc?
Old 02-08-2010, 08:50 PM
Best Logo's I've come across are on lyngsat. www.lyngsat-logo.com. The 'High-Quality' versions are transparent. Not in a pack though, and you'd have to go through and rename them to match your channel names, but as i said, they are the best quality available.
Random Example:
http://www.lyngsat-logo.com/hires/dd...channel_hd.png
Last edited by Opus4; 02-08-2010 at 09:26 PM. Reason: image too wide to be posted inline; changed to a link
Transparent Channel Logos karljayne SageTV Customizations 57 10-20-2009 06:32 AM
DirecTV Transparent Channel Logos mr_lore SageTV Customizations 2 09-27-2009 04:48 PM
I now have transparent menus with SageMC 6.3.8?? gveres SageMC Custom Interface 16 12-07-2008 03:22 PM
Help with a Transparent Graphic Cayars SageTV Customizations 16 11-09-2004 05:42 AM
VMR9 not transparent turak SageTV Beta Test Software 3 03-20-2004 06:50 AM
